Author Topic: Rear brakes DIY - any tips?  (Read 7048 times)
Offline shail
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99663.msg979899.html#msg979899
« on: May 23, 2018, 07:17:05 pm »
I'm planning on doing my rear pads and discs.
I've got all the bits, and a 14mm xzn socket for carrier bolt removal.  I read that they are a pain to remove - anyone got any tips / ideas to get those bolts out?
I've done this job before on a MK3 and MK4 so I know what to do - I'm just worried about not being able to take the carrier off.
Offline d0mokun
  • Merovingian Ninja
Re: Rear brakes DIY - any tips?
« Reply #1 on: May 24, 2018, 08:43:37 am »
Having done it twice now and despite having lubed the bolts etc, the best bit of advice I can give is to expect the two carrier bolts to be stuck- fast. You'll need a lot of clearance to get a big bar on there.
If they are stuck, you can get away with it by loosening the bearing and sliding that off the car. You can then angle the discs on and off. Not exactly a kosher method but it works if you're in a pickle.
Dan.
My current cars are:
08 S5 4.2 ¦ 79 Trabant P601L
Artist and car lover.
Offline mjmallia
  • -Receive: 60
« Reply #2 on: May 24, 2018, 09:34:56 am »
Done mine a couple of times now and no issues with removing the M14 bolts.......just a little awkward for access and unplug the ABS sensor.
I was expecting the worst when I first did them, but must have got lucky as it was not as bad for me.
Mike
South Coast
Offline shail
« Reply #3 on: May 24, 2018, 01:13:29 pm »
Two very different replies!
Im guessing I'll just have to have a go.
One question - I may have access to a vehicle lift at work, but wont be able to do the whole job on the lift, as I'll only get about 5 mins on it.  Is it possible to 'crack' the bolts and re-tighten them with the wheels on, and the car up in the air?  This might make the job easier when I do it at home on the drive.
Offline d0mokun
  • Merovingian Ninja
« Reply #4 on: May 24, 2018, 03:48:47 pm »
Mine's had a slightly unloved past and is a 55 plate car, just for reference. I doubt anybody ever took penetrant near any part of the car before I got it. Although if you read anywhere the consensus is that the bolts are buggers, so it may be just luck of the draw if they aren't.
I guess you could crack them but two things come to mind.. you've got very limited clearance anyway so probably even less with the wheels on, plus you'd then be driving around with 2/4 carrier bolts loosened. Good idea/ bad idea?
Dan.
Offline absolute
« Reply #5 on: May 24, 2018, 04:16:41 pm »
Couldn't get the clearance safely with a big bar, so opted to take it to a garage rather than risk it crushing me when I have one leg up in the air trying to get the bolt off.
Edition 30 #1994 now sold. *cries*
Offline GitFlog
« Reply #6 on: May 24, 2018, 04:31:57 pm »
When i did my rears before late years mot with a friend his impact helped us out with that god awful bolt took a good bit to get it out even with his air snapon impact.
At the end of the day give it a go if you cant get it off put it back together and take it to a garage.
2017 Vw Golf R Mk7.5
310ps
Lapiz Blue
Black Vienna Leather Interior
19" Pretoria Alloy Wheels
Dynamic Chassis Control
Offline shail
« Reply #7 on: May 24, 2018, 10:12:07 pm »
Guess I'll give it a go then.  Knowing my luck 3 will come off ok, but one will be a nightmare.
Offline shail
« Reply #8 on: July 23, 2018, 05:22:57 pm »
Fail!
Had a bash at this, and no combination of breaker bar or ratchet would work.
I've ordered some ratchet socket adapters which will allow me to put a 19mm spanner on the end of the socket - might give me the room I need, but probably not the leverage.
One more attempt then it's off to the garage :(
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #9 on: July 24, 2018, 03:45:20 am »
Here's a semi-thorough DIY; https://www.pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/127-BRAKES-Rear_Brake_Pad_Replacement/127-BRAKES-Rear_Brake_Pad_Replacement.htm
Some parts stores/houses have free rental of caliper compression tools, only needed for the rear on our mk5's, and makes it a bit easier than trying to compress and turn; https://www.autozone.com/loan-a-tools/loaner-disc-brake-caliper-tool
Offline muff1991
  • -Receive: 70
« Reply #10 on: July 26, 2018, 04:29:55 pm »
hi Shail, i did this job on my mates GTI and have done it on other cars very similar... they are really tight and the space you got is tight too! as you now know. But with the GTI i remember using a long ratchet bar. as my breaker bar was causing me issues! make sure you jack the car up nice and high to give yourself plenty of room (you already know but use axle stands!!!) and find the perfect length extension bar.. good luck.
  • -Receive: 692
« Reply #11 on: July 26, 2018, 07:55:00 pm »
I just used a 1/2” triple square socket in a regular breaker bar to crack them off, then a 3/8” socket set can take it from there.  The more ratchet teeth your wrenches and torque wrench have, the better.  The space available is only a click or two’s worth with Halfords wrenches.  Need a lot more than that, but you can generally fudge your way through it.
Really sh*tty design by VW.  Makes rear disc swaps 10x longer than it should.  Dealers must have specific tools.
Offline shail
« Reply #12 on: July 26, 2018, 08:33:19 pm »
@Pudding due to the length of my triple square socket and the size of the breaker head, I can't physically put the triple square end into the bolt.
Attempt 2 tomorrow.
  • -Receive: 692
« Reply #13 on: July 26, 2018, 08:42:51 pm »
Aye, it’s fruitin’ tight!
Fwiw, I used Halfords triple square bits (a rail selection in 1/2”) and a Halfords breaker and it only just fit, rubbing on the trailing arm slightly, but not enough to skew the tool angle.  That gave me about 3” of travel, which was just enough crack em’.  It literally is mm precise!
Offline Octoparrot
  • -Receive: 104
« Reply #14 on: July 26, 2018, 11:58:32 pm »
I had the same problem, you need really shallow triple square bits to be able to get a socket wrench or breaker bar on them, I ended up getting a set from BluePoint but there are cheaper alternatives on eBay.
https://browse.snapon.com/#/product/BLPXZNM389
« Last Edit: July 28, 2018, 03:06:35 pm by Octoparrot »
