Author Topic: URGENT- need help  (Read 2653 times)
Offline Rossmk5gti
URGENT- need help
« on: June 11, 2018, 01:17:50 pm »
The engine management light came on my MK5 2006 GTI yesterday with a loss of power. The engine has a whistling sound at idle that sounds like a siren the engine makes a horrible rattling sound like a diesel being revved around 4-5k. The code was cleared (air mass flow) and the car seemed to run a bit better, I drove it home (150 miles) and the light has not returned however, whilst driving the car the power lacks from normal and seems to die off and go flat at around 4000rpm. The car has low end boost just not as punchy as normal. I wondered if it was an air leak but can't explain the horrible rattle maybe the engine not firing correctly or an injector? Any ideas anyone?
Offline Christiank
  • -Receive: 39
Re: URGENT- need help
« Reply #1 on: June 11, 2018, 02:27:34 pm »
Check if any boost hoses has come off or something.. That would gives this problem.
Offline Rossmk5gti
« Reply #2 on: June 11, 2018, 02:33:14 pm »
What about the engine rattle at 5000 rpm??
Offline ady-gti
« Reply #3 on: June 11, 2018, 11:27:01 pm »
Diverter valve (DV valve) on the turbo is good possibility.
Offline Chesto18
« Reply #4 on: June 12, 2018, 06:37:20 am »
Did you replace the MAF or just clear the code?
If I had a loud whistling, an audible rattle from the engine, low boost and an EML my first thought would be dead turbo.
Offline mjmallia
  • -Receive: 60
« Reply #5 on: June 12, 2018, 10:07:06 am »
Blown turbo...........the noise haunts me now, when it gave up and shattered on my last car.
Mike
South Coast
  • -Receive: 692
« Reply #6 on: June 15, 2018, 06:14:51 pm »
Time to drop the down pipe and wiggle the turbo shaft to see how much play it has.   It does sound like it's very close to complete death from the symptoms.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #7 on: June 15, 2018, 06:37:25 pm »
Test your PCV and then look at the brake booster hose for splits...check all of the BB hose. Posting a vid while idling and slowly panning about up close might help us. Post the codes next time rather than deleting them. Give the exact code number/specification, OK?
« Last Edit: June 15, 2018, 06:43:51 pm by ROH ECHT »
  • -Receive: 692
« Reply #8 on: June 15, 2018, 06:52:56 pm »
Yeah the exact codes would be useful.   A MAF code isn't unusual alongside a blown turbo as the air volume drawn in is less than expected.
