Author Topic: Gateway / canbus update for rcd330  (Read 6802 times)
Offline slynch23
« on: August 13, 2018, 04:07:58 pm »
Hi guys, I’m looking at getting a rcd330 and they say you have to update the gateway to avoid battery drain. I already have a satnav in my car so will I still need to do this? Not sure which one it is but I’ve seen them in quite a few used GTi’s. It’s pretty cheap looking and needs a disc for the satnav. I’d upload a photo if I could figure out how on an iPhone! Any info is much appreciated.
Offline Pashka
Re: Gateway / canbus update for rcd330
« Reply #1 on: August 13, 2018, 05:56:35 pm »
If your golf is pre 07, yes you need to update it. I can sell you precoded one for your golf.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline slynch23
« Reply #2 on: August 13, 2018, 06:36:01 pm »
It’s a 56 plate so yes. How much?
Offline The Red Warrior
« Reply #3 on: August 14, 2018, 09:51:15 am »
Not necessarily. There is a canbus translator you can get which the seller says will stop battery drain and allow steering controls to work with the RCD330.
I'll see if I can find the link.
Here you go:
https://www.aliexpress.com/item/BODENLA-RCD330-MIB-RCD510-Multifunction-Steering-Wheel-Button-Control-Simulator-Adapter-For-VW-Golf-5-6/32847626802.html
« Last Edit: August 14, 2018, 10:01:05 am by The Red Warrior »
Offline Mobrrown45
« Reply #4 on: August 28, 2018, 09:22:04 pm »
I used this Canbus adapter with an rcd330g and it worked a treat, steering controls all worked fine too.
http://s.aliexpress.com/aAbA3qmQ
Shelfsider
« Reply #5 on: August 30, 2018, 10:28:18 pm »
Changed my canbus today after RNS 510 Q caused battery drain. Bought second hand AD prefix canbus off eBay for £20 delivered, all fitted & coded in about 20 minutes :happy2:
Offline slynch23
« Reply #6 on: September 03, 2018, 04:25:01 pm »
Did you buy it precoded? If so, could you send me a link
