Author Topic: Miss fire at idle ed30 gti  (Read 1468 times)
Offline e4n94
« on: November 10, 2018, 05:31:27 pm »
I have a 2008 golf gti 30 edition I have recently noticed the car Miss firing on idle and only on idle I have put the engine under load but runs ok no problem. I change the spark plugs 2 months ago and recently change one coil pack due to a code p0302 cylinder 2 miss fire but still the car Miss fires on idle.
The other code I have is Random cylinder missfire p0300. I was thinking it could be a injector so I tried some red X but still no joy. Am I right in saying it could be down to carbon build up in the inlet and if so how much of a job is it to remove the inlet manifold
  • -Receive: 691
Re: Miss fire at idle ed30 gti
« Reply #1 on: November 16, 2018, 06:53:42 pm »
Injector.  Probably number 3.  It's only noticeable at idle because of it's the lowest rail pressure.  Give it some throttle and the pressure increases and overcomes any blockages/mechanical pintle wear.
