Author Topic: MK5 Cam chain & tensioner being done advice please  (Read 1933 times)
Offline Lucky ducky
  • -Given: 30
« on: January 29, 2019, 08:29:29 pm »
Have a 2005 with 75k with the above being done soon is there any other preventative maintenance that you'd do while my mechanic is at it?
Offline Alex Booth
  • AKS Tuning
    • AKS Tuning
Re: MK5 Cam chain & tensioner being done advice please
« Reply #1 on: January 30, 2019, 10:52:38 am »
All depends on what has been done in the past. If there is no history of the Cambelt + Waterpump, Cam Follower, DSG service (if auto) being done then these should be done around your mileage, if not sooner. May also be worth checking you have the latest revision PCV & Diverter Valve as well. Pick up pipe worth changing as they can become blocked as well. Lots of other small things but worth checking if any of the above have been done previously.
« Last Edit: January 30, 2019, 12:04:17 pm by OllieAKS »
Offline Pesky jones
« Reply #2 on: January 30, 2019, 11:32:59 am »
May as well do the cam follower whilst you're there, if it hasn't been done recently and looks worn.
  • -Receive: 692
« Reply #3 on: January 30, 2019, 11:38:40 am »
Probably worth dropping the sump to replace the pickup and clear away any sludge.   It's very common for GTIs on longlife servicing to suffer from pickup pipe blockages, which can write the engine off quite easily.
