Author Topic: VW premium bluetooth fitted, but bluetooth not active???  (Read 25725 times)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: VW premium bluetooth fitted, but bluetooth not active???
« Reply #45 on: February 21, 2010, 12:36:41 am »
I would suggest -
0013000 if you have Voice control or 0013020 if you dont.
Stu...
Offline mortygttdi
  • -Receive: 146
« Reply #46 on: February 21, 2010, 09:16:40 am »
Cheers Stu will have a go at that when i can get chance to get around to Garths.  unfortunately its snowing like it was the artic :confused:.
Darren
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #47 on: February 21, 2010, 09:53:24 am »
After changing the coding you will be best to delete the current pairing and re-pairing the unit to the phone.
Let me know how it goes.
Stu...
Offline mortygttdi
  • -Receive: 146
« Reply #48 on: February 21, 2010, 10:10:04 am »
will do  :happy2:
Darren
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #49 on: June 19, 2010, 04:44:33 pm »
Yes I have the 729E fully working with the cluster display, multi-function steering wheel and touch interface on the RNS-510. I am at work at present so can't confirm what coding. My car is an Aug 2009 Mk6 GTI.
I may be able to get hold of a 729E module if your interested?
Where abouts are you based as I can help code it if required?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #50 on: June 19, 2010, 06:13:07 pm »
I have been using a car with the premuim kit this so upgraded my work blackberry to the an rSap compatable one and while it's a slightly better kit on in car features etc, but has serious limitations with stuff like the phone being basically disabled (so no email or texts) while connected to the car. I am very glad I swapped it over to the 729E kit.
I will drop you an email later tonight once I am home  :smiley:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #51 on: June 21, 2010, 10:04:34 am »
I would leave it in for now as it will trigger a fault on the CAN Gateway (not visible anywhere other than via a diagnostics cable).
Offline mortygttdi
  • -Receive: 146
« Reply #52 on: June 22, 2010, 06:12:19 am »
Steve you ever heard of any one swapping out a 729B for an 729E I had someone round to check the BT on there car cos it would not connect but on the box its saying 1Z0 035 729B and on the VCDS screen module 77 its reading 729E???? :surprised:
Told him to contact the seller and get some answers, sounds like they have changed the inside to make abit of profit.  What with the B been much more sought after and more expensive.
Darren
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #53 on: June 22, 2010, 06:19:16 am »
Darren
From what I know of this Darren the person concerned bought the interface over a year ago as a 729B however as you say it appears to have a 729E inside it.  So far as I know the 729E wouldn't have been available over a year ago.  So I think it may point towards the installer myself.
Are you 100% sure it is reported as being a 729E?  It really doesn't add up does it??
Stu...
Offline mortygttdi
  • -Receive: 146
« Reply #54 on: June 22, 2010, 08:03:38 am »
Hi Stu I had to look a few times but VCDS reported a E version and the sticker on the module says B version :confused:
What I can't understand Stu is although it is an E version why its still not connecting to the phone?  I thought it would still see and connect to the phone but just wouldn't show in the red highline.
Darren
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #55 on: June 22, 2010, 08:43:16 am »
Exactly mate, a 729E if installed correctly, should work with a MK5 except for the Highline as you say.
I can't see how it can be anything other than the installer.  I don't know who it was, I think it was a company.  If the person concerned has had the unit for a year then I just can't see how it can be a 729E.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #56 on: June 22, 2010, 08:44:59 am »
Did you do an Autoscan of the car??  Can you post it up?
Stu...
Offline mortygttdi
  • -Receive: 146
« Reply #57 on: June 22, 2010, 09:03:58 am »
No scan I'm afraid Stu I do usually do a full scan on every car but my netbook's battery is on its last legs and won't keep a charge so could only take a quick look at the coding,
The coding was set at 00000422, the thing I did find weird was that I couldn't get into any adaptations to see the passcode or anything it was grey'd out?
Also the coding itself could not be changed it just kept given me an error. Sounds like a faulty module?
Darren
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #58 on: June 22, 2010, 12:33:40 pm »
422 wouldn't have been the correct coding for that module.
Any errors on CAN to perhaps indicate a broken wire/connection?
Stu...
Offline mortygttdi
  • -Receive: 146
« Reply #59 on: June 22, 2010, 04:59:47 pm »
Every thing was fine no fault codes at all :sad1:
Darren
