Author Topic: What is the EVAP Emission Control System?  (Read 16982 times)
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
Re: What is the EVAP Emission Control System?
« Reply #15 on: February 19, 2010, 11:17:19 pm »
Mater does the fault put the engine light on? I know on the american tfsi's if the petrol cap is loose or faulty it can create that fault with a light though.
No mate. I've only seen it about 4 times in the 3 years i've had the car.
If it becomes more frequent i will get the Charcoal Canister replaced
Carl :happy2:
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #16 on: May 27, 2010, 08:15:18 pm »
Where's this "Charcoal Canister"?
« Reply #17 on: May 27, 2010, 08:21:08 pm »
^ The square box in front of the screenwash filler.
  • MUBster DUBster
« Reply #18 on: May 27, 2010, 08:28:46 pm »
Cheers RR - what does this thing do?  Is it something that needs to be replaced/serviced after a certain number of miles?
I must admit I have never seen it in my car.
« Reply #19 on: May 27, 2010, 08:32:55 pm »
I hope you have seen it! You won't get through UK MOT without it.
It filters fuel vapours I think. They don't need to have them in the U S of A.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #20 on: May 27, 2010, 08:42:01 pm »
If you are getting the EVAP fault then check this hasn't happened.
This is why I was getting it and since fixing that it hasn't been back touch wood.
Offline 56OctyVRS
  • -Receive: 72
« Reply #21 on: December 31, 2011, 11:42:15 am »
A friend of mine had one on his car go and it killed his mpg and the engine ran really rough. Since replacing it his engine is back to normal. I think he paid about £80 or there abouts for a new cannister.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #22 on: December 31, 2011, 10:04:01 pm »
Check the breather pipe first as that is about £9 to replace. A charcoal canister is about £95
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« Reply #23 on: December 31, 2011, 10:40:38 pm »
I personally don't think it will have any effect. I had to have mine changed and didn't notice any difference in MPG when it was faulty.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #24 on: December 31, 2011, 11:19:04 pm »
I never noticed any difference with MPG either when I replaced the pipe.
Offline martziniuk
« Reply #25 on: January 01, 2012, 10:49:59 am »
I never noticed any poor running or mpg change when I had the evap fault code but the canister did fix the code. A bad PCV seems to cause a lot of running problems.
« Last Edit: January 01, 2012, 10:52:53 am by martziniuk »
