September 10, 2026, 01:34:17 am
All Things Mk5
Mk5 General Area
Pressed plates what to stick on with
Topic: Pressed plates what to stick on with (Read 1883 times)
Woozor
Newbie
-Given: 0
-Receive: 0
November 03, 2019, 10:08:41 am »
Hi guys I got some pressed plates and used the Halfords sticky pads 1mm but the front one is coming off after a few days the rear seems fine.
What's the best stuff to stick it on with?
titchy
Won't Shut up.
-Given: 0
-Receive: 33
Re: Pressed plates what to stick on with
Reply #1 on:
November 03, 2019, 05:29:13 pm »
make sure you clean both surfaces with alcohol wipes
joe2308
Can't Read PM's Yet!
-Given: 0
-Receive: 0
Reply #2 on:
November 03, 2019, 05:35:19 pm »
I used some 3M tape for mine, with a really clean surface and they have been stuck solid since
Eighteen88
Reply #3 on:
November 03, 2019, 07:27:44 pm »
Have a look at a number plate surround, they can be screwed directly onto the car then the plate is clipped into the holder.
terrier
Always Involved
-Given: 12
-Receive: 41
My Ride:
Reply #4 on:
November 03, 2019, 09:04:28 pm »
sticky backed velcro As titchy said wipe clean with alcohol, IPA or nail varnish remover if you own some
Ive been using 50mm x 250mm strips NEVER let me down and easy to remove if you need to..EBAY 122692257955
Mark_DF05
Always Involved
-Given: 23
-Receive: 9
Reply #5 on:
November 04, 2019, 12:40:44 pm »
I got fed up of the front one coming off every couple of years so screwed them on in the end. Best result I had was the velcro strips though as others have said.
andyR43
Always Involved
-Given: 11
-Receive: 32
Reply #6 on:
November 04, 2019, 06:46:50 pm »
I used double-sided carpet tape. No problems even after 5 years.
Keeping it original..............or not!!
LC5F
Just look at my post count
-Given: 16
-Receive: 80
Reply #7 on:
November 05, 2019, 08:20:17 pm »
Interesting suggestions, I’m tempted to try Velcro.
Double sided foam can be hit or miss - Halfords stuff ain’t good - properly branded 3M stuff works well
All Things Mk5
Mk5 General Area
