Author Topic: Brake Noise  (Read 1320 times)
Offline rubdub
  • -Given: 19
Brake Noise
« on: May 04, 2020, 04:47:01 pm »
Hey guys,
So for the past while I've had an issue with my rear NS brake. If I'm travelling around 70kmh there's this consistent dun-dun-dun-dun noise and doesn't seem to change pitch even if I brake a bit. There's also times when I've let the handbrake off to reverse out of the drive and the brake is bound to the caliper, and takes a bit of gas to release.
I've been reading a few previous posts on the forum and I can see that this is a common problem with the MKV brake set up.
My question is, is there any way to determine if the caliper is the issue or if it's a bent slide pin without taking the whole thing off?
Thanks!
Offline muff1991
  • -Receive: 70
Re: Brake Noise
« Reply #1 on: May 05, 2020, 09:39:58 am »
The rear caliper comes off easy with only 2 bolts holding it on. The slide pins can then be pulled out to inspect.  Providing your discs and pads are all in good shape, then It sounds like a binding caliper. Which means you’ll either have to buy a caliper rebuild kit or replace the caliper.
Offline rubdub
  • -Given: 19
Re: Brake Noise
« Reply #2 on: May 05, 2020, 11:17:09 pm »
Thanks muff1991!
