Author Topic: Washer jets slow operation  (Read 1813 times)
Offline chimp400
  • -Given: 46
« on: May 13, 2020, 06:33:41 pm »
My jets take a few seconds to respond meaning the wipers will wipe a dry screen, not ideal.
Is there a non return valve in the system I could check/replace or anything else I need to check?
Offline titchy
Re: Washer jets slow operation
« Reply #1 on: May 13, 2020, 06:41:22 pm »
check the jets are not blocked I use a welding tip cleaner
Offline terrier
  • -Receive: 41
  • My Ride: GTI now gone
« Reply #2 on: May 13, 2020, 07:15:53 pm »
Completely empty the reservoir fill with hot ,not boiling water and run through the system.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #3 on: May 13, 2020, 08:04:49 pm »
Perhaps a bit of vinegar to this?
OP, yes, I believe it should have a retention valve at its output. However, this would only delay the initial spraying and then would be normal. Are you sure there are no leaks in the supply tubing? A small leak in the tubing further toward the pump would allow the fluid to drain from the tubing when not in use and delay spraying and the stream may appear normal. A larger leak would delay spraying and result in less volume.
Mine cracked here and I repaired it;
I have the replacement tubing, but I did this repair 7 years ago and is still holding. I am waiting on installing the new tubing until needed. You may need to remove the access covers under the bonnet/hood to see if it is wet in there.
If you do not see improvements with cleaning the nozzles and no leaks are discovered, then you may need a new washer pump.
« Last Edit: May 13, 2020, 08:15:35 pm by ROH ECHT »
Offline chimp400
  • -Given: 46
« Reply #4 on: May 13, 2020, 09:18:20 pm »
I’ve not looked at it yet but will get round to it over the next few days, thanks all.
