Author Topic: Bonnet won’t open!!  (Read 8515 times)
Offline Kristian
Re: Bonnet won’t open!!
« Reply #15 on: July 01, 2020, 02:47:26 pm »
Surely someone must have had a broken bonnet cable and knows how to open it!
Offline titchy
« Reply #16 on: July 01, 2020, 04:12:04 pm »
Yes but they show lots of info on how to tackle work and problems
Offline fakie1977
« Reply #17 on: July 01, 2020, 04:15:12 pm »
Yes as stated above - it contains technical documents which has helped me lots. See link but it’s not going to help in this case as it assumes the bonnet is open.
https://www.pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/25-BODY-Hood_Lock_Replacement/25-BODY-Hood_Lock_Replacement.htm
Offline pandaman
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,115571.0.html
« Reply #18 on: July 01, 2020, 05:54:30 pm »
That’s a US car parts store?
They also have very good photographed how to's on a lot of things, they may have one that will be helpful.
Offline Kristian
« Reply #19 on: July 02, 2020, 02:40:46 pm »
I honestly really appreciate the help guys, however, I couldn’t find any technical articles that talk about broken release cables. As I said before, surely someone has had the same issue! I am open to any suggestions, if I took off the undertray could I get to it? Or will the radiator be in the way?
Offline Kristian
« Reply #20 on: July 02, 2020, 02:43:44 pm »
Do you guys know of a detailed diagram of the front end?
Offline fakie1977
« Reply #21 on: July 02, 2020, 02:54:56 pm »
I may be not be understanding properly your issue but if you watched the video of Micks Garage on YouTube it doesn’t matter if your cable is broken or not as you pry the bonnet lock mechanism directly with a screwdriver. Isn’t that what you are trying to do?
Offline titchy
« Reply #22 on: July 02, 2020, 04:11:14 pm »
Go to a breakers yard see if you can look at s/hand one off the car you will see where lever it open
Online Octoparrot
  • -Receive: 104
« Reply #23 on: July 02, 2020, 05:02:58 pm »
the only other alternative is to smash the grill to bits so you can get at the lock.
Offline bobby_fodge
  • -Given: 22
  • -Receive: 39
« Reply #24 on: July 02, 2020, 06:30:03 pm »
You need to be able to see the 'hook' that swings down into the front panel.
With a past BMW I had I ended up smashing the plastic grill up so I could get a long screwdriver in so I could flick that 'hook' up and out of the front panel.
Offline Kristian
« Reply #25 on: July 03, 2020, 12:42:07 pm »
Thanks again for your reply, the issue I’m having is that with Micks video he can you the cable as leverage to move the rotating part that then releases the latch. If I don’t have the cable attached I cannot work our how to gain that leverage. Unless as the other guys say is just cut out the area to be able to reach it. Wish there was another way!
Offline Kristian
« Reply #26 on: July 03, 2020, 12:45:20 pm »
It’s such a small area that there is no way to see into it, I can feel the rotating part with my fingers but just cannot get the leverage (cut my hands up a few times trying). I also don’t want to destroy the inside panel! There must be another way!
Offline fakie1977
« Reply #27 on: July 03, 2020, 12:48:32 pm »
Maybe this can help. I used the instructions on this website to change my locking mechanism so it may show you how it looks like and the things around it to orient yourself to it?
https://www.stuartdalby.co.uk/vwgolfmk5/bonnet_catch/index.php
Offline Kristian
« Reply #28 on: July 03, 2020, 12:50:01 pm »
I just do not want to do that if there may be a less destructive way. Do you think you could reach it via the wheel arch if you took the wheel and lining off?
[/quote]
Offline Kristian
« Reply #29 on: July 03, 2020, 12:51:36 pm »
@fakie1977 thank you for the article! I will have a read!
