Author Topic: Cruise retrofit  (Read 906 times)
Offline shoaybmakda
  • -Receive: 54
Cruise retrofit
« on: June 20, 2020, 09:08:29 am »
Hi all
Hoping someone will be able to advise - I've done a cruise retrofit on a mk5 GTi before but wanted to check for the mk6.
1) The car having the stalk fitted on is a 2010 facelift GTD DSG (LED Rear lights instead of the halogen). The car has multifunction steering wheel so I assume the steering wheel controller should be ok? If not - is there any way to check this without taking it all apart to check?
2) I've read in some places that VW have changed the stalks on 2010 cars and instead of it being a single stalk change it would require a dual stalk. Is this correct?
3) with it being DSG - I assume the cruise wire would be in place and I wouldn't need to fit this?
Sorry if any of my questions are not clear! Thank you for any help given
