Author Topic: Camber query  (Read 3336 times)
Offline Enviousog
Camber query
« on: July 19, 2020, 02:51:37 pm »
I know people have asked and I've searched but the answer wasn't clear
On the mkv gti, the rear axel camber is adjustable, but which bolt is it?
« Last Edit: July 19, 2020, 02:56:26 pm by Enviousog »
Offline LC5F
  • -Receive: 80
Re: Camber query
« Reply #1 on: July 19, 2020, 03:30:27 pm »
Stolen from VWvortex:
Offline Enviousog
Re: Camber query
« Reply #2 on: July 19, 2020, 03:47:44 pm »
Thank you pal
  • -Receive: 691
Re: Camber query
« Reply #3 on: July 20, 2020, 11:29:54 am »
Great pic  :happy2:
Before attempting to adjust the toe, I would buy a pair of bolts/nuts from VW first. They seize up and often need to be cut off if heat and impact guns don’t budge them.
The camber bolts seem to be fine.
Offline muff1991
  • -Receive: 70
Re: Camber query
« Reply #4 on: July 21, 2020, 03:12:08 pm »
the rear camber and toe bolts are totally seized in mine, i'm waiting to order a full polybush set for the front and rear then ill drop the whole rear end cut it all out and pop new bushed and bolts in, loads of effort for a bit of camber being out but its not perfect.. has to be sorted lol
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Re: Camber query
« Reply #5 on: July 21, 2020, 05:20:38 pm »
Same here, have new bolts and bushes at the ready.
Offline imprezzaworks
Re: Camber query
« Reply #6 on: July 21, 2020, 06:26:55 pm »
I'm assuming mine had been replaced as they moved well when the were adjusted
Offline muff1991
  • -Receive: 70
Re: Camber query
« Reply #7 on: July 22, 2020, 12:37:05 pm »
i've had the bolts for a while i just need to get the bushes.. probably going to grab the cheap set off ebay at some point tbh (PSB i think it is, they're not too bad i have replaced a couple on the touran with them)
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Re: Camber query
« Reply #8 on: July 22, 2020, 01:09:27 pm »
I bought a full set of PSB but only fitted the front as the bolts on the rear won't move hence me getting the bolts in anticipation of them needing to be replaced. I don't want the car stuck in the air as a bolt has snapped.
Offline muff1991
  • -Receive: 70
Re: Camber query
« Reply #9 on: July 22, 2020, 01:46:52 pm »
i agree @bobby_fodge i'm pretty sure ill be dropping the whole rear frame on mine and angle grind them all out! the camber bolt is hard to get to at the best of times! let alone when its seized!
