Author Topic: Screw in a pipe in engine bay, don't know why  (Read 1983 times)
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
« on: August 03, 2020, 12:04:02 pm »
I don't how else to put this, but I found this on my mid-2005 GTI.
I think, from looking at other pictures online, that it's meant to go via a pipe across the engine to this location, but I'm not 100% sure as I can't find detailed pictures of it.
Here's a picture I found online
Does anyone know what it was and why someone would remove it and block it up with a screw?
Thanks!
Offline titchy
Re: Screw in a pipe in engine bay, don't know why
« Reply #1 on: August 03, 2020, 01:57:14 pm »
Its been blocked to stop a vacuum leak
  • -Receive: 453
« Reply #2 on: August 03, 2020, 05:37:42 pm »
That's a diy fix to block off that pipe.
there is a specific  vw plastic cap to cover/block off that bit for a mk5.
as long as it's not leaking you're all good to go...
Offline Rossimac
  • -Given: 78
« Reply #3 on: August 03, 2020, 10:05:07 pm »
Don't think it's causing any issues, so will leave it alone! Thanks!
Offline mjmallia
  • -Receive: 60
« Reply #4 on: August 04, 2020, 09:02:07 am »
As mentioned it is supposed to be blocked off with out engines and there is a special cap that TPS/dealers can sell you to tidy it up.....although it is green now, as recently got one when I replaced that valve.
Mike
South Coast
  • -Receive: 692
« Reply #5 on: August 08, 2020, 01:06:19 pm »
I think maybe someone has run a boost gauge in the past?
Early elbows didn't have that spout (mine doesn't), but I've seen if you buy a replacement vacuum pump hose now, it comes with that spout and is normally plugged with a plastic bung.
