Author Topic: TRW drop links  (Read 1079 times)
Offline Rigsby
  • -Given: 22
TRW drop links
« on: August 08, 2020, 08:53:03 pm »
Just fitted a set of these and was baffled that they had no torx/spline In the end of bolt? Had to grind down an open ended spanner to fit on the back to stop them spinning, which was a pain .
Is this normal or have I been given dodgy parts?
Offline LC5F
  • -Receive: 80
Re: TRW drop links
« Reply #1 on: August 08, 2020, 09:29:56 pm »
Yes - I recently installed a set of these - this style is a lot better than the spline ones
But I am lucky enough to have several sets of spanners the slimmest fitted.
It could be worse, Mk4 ones are even tighter I had to break out Cycle spanners that are 3mm thick.
