Author Topic: Ed30  (Read 1950 times)
Offline Eddy30_vinny
  • Newbie
Ed30
« on: October 27, 2020, 01:25:50 am »
Hello I’m new to this site hoping someone can help me out with some info as to what mite be wrong with my eddy30 I have no compression on cylinder one two and three are 70psi and four is 150psi now am I right in thinking that maybe the head has lifted or what as I’m lost 😞
Offline titchy
Re: Ed30
« Reply #1 on: October 27, 2020, 11:41:05 am »
could be worn piston rings have you checked the spark plugs are seated correctly? Have you done a wet test?
Offline GVK
  • -Receive: 77
    • GVKmotorsport
Re: Ed30
« Reply #2 on: October 27, 2020, 07:46:29 pm »
Broken pistons at a guess , ringland failure.
Head off, sump off, pistons out.  :sick:
  • -Receive: 692
Re: Ed30
« Reply #3 on: October 30, 2020, 04:22:59 pm »
Heads don't lift on these engines unless running silly boost from a hybrid turbo, or massive detonation.
As you haven't mentioned the spec of the engine at all, I'm going to hazard a guess it's had a Stage 2+ remap, with pops and bangs (natch), and it's either burnt out the exhaust valves, or smashed the ring lands as GVK said.
If the latter, you got off lightly, throw a new head on it and go about your business.
If the former, chuck the motor in the bin and get a new one.
  • Newbie
Re: Ed30
« Reply #4 on: October 30, 2020, 06:18:38 pm »
It is a stage3 no pop and bang and it has a bbt 430 k04
