Author Topic: Number plate light reverse cam?  (Read 6492 times)
Offline blingsta
« on: June 30, 2021, 04:54:12 pm »
hi all..
having fitted my android headunit,  im now itching to make full use of it, so im interested in fitting a reverse camera..   i want a camera that doesnt stick out like a sore thumb  :signLOL: and was wondering what you chaps have (boot logo camera not included)   :grin: although i would very much like a boot logo one, im pretty sure its way out of budget compared to the £25 one ive seen  :signLOL:
has anyone tried or have this camera? - https://www.ebay.co.uk/itm/383726360020?_trkparms=ispr%3D1&hash=item5957df95d4:g:DQkAAOSwLFJfZHVh&amdata=enc%3AAQAGAAACkPYe5NmHp%252B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSQuF9OYLb3wphIAOfpJK8RiYcssPi4J78t046D8Txj8SObgKJQWzNtVhjs3Ma6%252FgtSRAIhnMyQV%252FuZgjNPHrOQoI5NPAOvsn0SKxMffb05%252F6%252B5LWB6anPLi%252Fv4SFJZo9WRw98NUo5ZedcOAtPvBiXQLlhcpxa9ktfzahOrlUbdJmwz2QB7WnjWQD8M333im1naYnLpFo%252BT80UcO3BmvFNNZbY4clLGzMuPWFWiCAwgd1TcgvkvIEI1nCK8SwIRiIEH%252Fg44CiYAwm61kO3pTTmoi%252B9QyukHNcYgIJA4JS8vBZbvjFncRsO1mNRnVqHLFjahQq9BW2qM6dp1AwZGM7RqJlZD6nix2J8OIkSdYti%252B3V%252BiVOvb8QaNXaJMHwXXTR6WFxU7%252FejW5vP7GFoD6Pc4rrVppLaOUMs9C8AaVykaNDBmHSdR694uXqHTJ4RC724qRmeRytIC48vx9fdINeHcWctjisxzSVVoDCRPBxHUdAqIStO8jOjR4oDEv9gpRw5NHhYfjMdOZOjAH8h8BHTLPDpWooKQoFml3RAYeDa49sTYcDS1xbzCZ%252Be2Iade4t57wjg7ohfeub1DLDXgnvQyvOr2Jq39blAq2avKnwsxxo5egOPlwBy1znu63ILayigLOsFtzP1pk8IGLtVkwz3sLssCP8zENdgbhzsBScQLJHmOevVphZdT6jJXp%252FYtjnCO61c9G%252BQRWdbOXtuW%252FkWfdfBkTgIFgAFmkkoFL4LybY3qVAo96IEp09nxEThRVbOps8xdg3HE8eWWdA0OTxO2d8qnjoAchizLTO6fn4Arj5y%252FN%252F6ropvBB%252Fb4pQme9no%7Campid%3APL_CLK%7Cclp%3A2334524
Offline blingsta
Re: Number plate light reverse cam?
« Reply #1 on: June 30, 2021, 04:55:46 pm »
if anyone can maybe share a picture how this actually looks on the car, i would appreciate it  :happy2:
Offline LC5F
  • -Receive: 80
« Reply #2 on: June 30, 2021, 07:36:29 pm »
I would be concerned about light output - would it be the same on both sides of the plate - don't think that would fail MOT, but may be a fail visually.
I'm going for something like this mounted between the lights, it will require a hole cutting in the bumper, but it should be discrete:
I'm toying with a front too:
Offline blingsta
« Reply #3 on: June 30, 2021, 11:25:52 pm »
Thanks for replying fella  :happy2:
Your choice of cameras are perfect... :congrats:
Offline shail
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99663.msg979899.html#msg979899
« Reply #4 on: July 01, 2021, 06:53:59 am »
I have one of those number plate light cameras.
I got the non led one, so both lights match.  You use your existing bulb and connector - but I had to buy a used light from a polo as the connector in my golf didn't fit inside the new camera fitting.
I wouldn't recommend it to be honest.  The camera points too far down, so you can only see the ground, and hardly any of the surrounding areas because of the way the camera is angled.
Offline blingsta
« Reply #5 on: July 01, 2021, 03:08:31 pm »
Very helpful unfo mate... thank you
Offline blingsta
« Reply #6 on: July 01, 2021, 03:10:12 pm »
Where did you find that reverse cam mate?
Offline mo
« Reply #7 on: July 01, 2021, 04:50:11 pm »
I have this style camera.
https://www.ebay.co.uk/itm/333810899726?hash=item4db8ae1b0e:g:zmgAAOSw8WJffseG
There's a hole in our bumpers between the 2 number plate lights. this fits perfectly and vision is good.
2007 Ed30 Superchips Bluefin Stg 1
RNS510 & MDI
Offline mo
« Reply #8 on: July 01, 2021, 04:51:56 pm »
I have the front camera and the control box to swap vision from rear to front when moving from reverse to drive. Not got round to fitting after almost 2 years  :grin:
RNS510 & MDI
Offline blingsta
« Reply #9 on: July 01, 2021, 08:53:39 pm »
ive also had my eye on this one too Lol...     mine will also be going in between the plate lights..   do you have any pics of your rear end pls fella  :signLOL:
i would love to see if it blends in well and looks discreet
Offline LC5F
  • -Receive: 80
« Reply #10 on: July 01, 2021, 08:54:50 pm »
Aliexpress - https://www.aliexpress.com/item/33032367610.html?spm=a2g0s.9042311.0.0.626e4c4d9KPEl2
literally arrived today, 16 days to arrive, hope it works. even comes with its own 20mm hole saw...but it seems that there is a hole ready made
Yes - that's the problem with the Mk5 plate being so low and I cant think of a place higher up to mount a camera discreetly.
Yep - found that, its 19.6mm in diameter - perfect snug fit for mine - Any problem removing the clip and how was the camera angle there?
Offline blingsta
« Reply #11 on: July 01, 2021, 10:31:25 pm »
this one looks as though its slimline and discreet...    not sure about the big nut and bolt though !   if the nut comes off, i would be looking to use double sided 3m tape to stick it on
https://www.ebay.co.uk/itm/124384307100?epid=22033838106&hash=item1cf5e1e79c:g:bfYAAOSwk-Bdibiu#rwid
Offline blingsta
« Reply #12 on: July 01, 2021, 10:48:10 pm »
think i just found the same as yours on ebay -
https://www.ebay.co.uk/itm/333778162158?epid=22033838106&hash=item4db6ba91ee:g:O0EAAOSwLKxfo2d9
how does it look in person fella?    does it look like it would be discreet between the 2 plate lights?
Offline LC5F
  • -Receive: 80
« Reply #13 on: July 03, 2021, 01:35:11 pm »
That's over double the price of mine!
I am unsure when I will get round to installing mine, got several tasks lined up and this is low on the list - could be weeks or months!
Here's a picture to show the size:
Offline blingsta
« Reply #14 on: July 04, 2021, 01:09:48 am »
Well I didn't think toeasure mine, but received and fitted today...  and I'm so happy with the choice of camera, its so small and discreet with a brilliant picture, it also came with a voltage correction ballast
https://i.imgur.com/ZkJjO9o.jpg
https://i.imgur.com/s6KYnMi.jpg
https://i.imgur.com/rvc5Oqz.jpg
Well worth the £25  :happy2:
