Author Topic: Airtec intercooler  (Read 1489 times)
Offline Birty_
Airtec intercooler
« on: January 19, 2022, 07:45:12 am »
Morning all,
I've just got round to fitting my airtec intercooler to my Edition 30....
Car doesn't feel overly great, it's got a bit of a boost leak as it's very hesitant and spikey low down.
Noticed there was oil coming from the driverside intercooler pipe where the alloy coupler connects engine side.
I assumed, maybe wrongly that with the new airtec hoses and jubile clips that I'd do away with the flimsey rubbish o-rings and mental clips.
I'm just wondered if, the airtec stage 2 cooler needs no.8 on the diagram? That connection is where the leak is.
Wondered if someone who's fitted an airtec could advise?
Thanks in advance.
Sent from my Pixel 6 using Tapatalk
Offline Trav Turbo
  • -Given: 18
Re: Airtec intercooler
« Reply #1 on: January 19, 2022, 08:18:16 am »
When I fitted mine it was a hard job to get the coupler little alloy joint to clip into the intercooler pipe on the car with the O ring placed on, had to tap it in with a rubber mallet until it clipped in.
Sent from my SM-N950F using Tapatalk
Offline Birty_
« Reply #2 on: January 19, 2022, 03:20:12 pm »
Thanks for this, I think I'll pull that hose off again and try again. I guess I'll replace the o-ring and see how that goes as my alloy couple just slots on and off very easily although the silicone hose makes it a tight fit.
Do you mean the metal circlip which comes off with a flat head that you hammered on? Or the actual alloy coupler with the rubber o-ring?
Thanks again.
Offline Trav Turbo
  • -Given: 18
« Reply #3 on: January 19, 2022, 04:28:54 pm »
Yeah I hammered the coupler with the O-ring on into the pipe with the circlip first and make sure it clipped it securely. Then fitted the silicone hose after
Offline Birty_
« Reply #4 on: January 19, 2022, 05:09:38 pm »
Awesome, I've just done this. Already feels tonnes more secure, will take it for a spin later.
Thanks dude, appreciate your help.
Offline Trav Turbo
  • -Given: 18
« Reply #5 on: January 19, 2022, 05:47:26 pm »
No worries mate!
