Author Topic: Black spots on trunk 2.0tfsi  (Read 4543 times)
Offline Keks3003
« on: February 22, 2022, 02:29:14 pm »
Hello guys, im having problem with my mark 5. Every time after ride i have black marks on trunk. I dont what could be it. Oil is ok, in 6000km only 0.6 did take, so oil isnt... Any idea ?
  • -Receive: 692
Re: Black spots on trunk 2.0tfsi
« Reply #1 on: February 22, 2022, 03:49:11 pm »
Sooty tune?
Offline Keks3003
« Reply #2 on: February 22, 2022, 05:45:06 pm »
Could it be from faulty thermostat ? Just came from drive, and the car did not get to 90° after 25min of ride....
  • -Receive: 692
« Reply #3 on: February 22, 2022, 07:56:19 pm »
Yeah I would replace the thermostat first and go from there.
Offline ljc19630
« Reply #4 on: February 22, 2022, 10:13:46 pm »
Can you see if the thermostat sits at 90degrees? That’s also a sign that it needs replacement if not ?
Offline DBXdarkangel
  • -Given: 18
« Reply #5 on: February 22, 2022, 10:39:01 pm »
Black exhaust soot is faulty thermostat? Interested in this as mine has black soot for past 5 yrs
Offline Keks3003
« Reply #6 on: February 23, 2022, 04:26:12 am »
No doesnt sit at 90, only at stop will come to 90.  I will try to replace it.
  • -Receive: 692
« Reply #7 on: February 23, 2022, 09:28:46 am »
It's not the sole cause, but a contributing factor.
TFSIs are very sooty engines anyway because of how they operate.  Remaps compounds the problem but I've seen standard cars chucking out black smoke under hard acceleration as well, so not a lot you can do about it really, other than convert the engine to port injection!
Offline Mekaniko
« Reply #8 on: February 23, 2022, 04:33:43 pm »
Mine have the same... maybe the coils? As all the petrol could not be burn?
Offline RBS
  • -Receive: 49
« Reply #9 on: February 23, 2022, 07:07:23 pm »
 :thinking: Isn't that just condens which is blow out of the exhaust?
  • -Receive: 692
« Reply #10 on: February 24, 2022, 09:24:50 am »
I would only expect steam/boost to blow some accumulated soot out of the exhaust if it does mostly short journeys, but a daily driven car doing a reasonable amount of miles shouldn't do that.  Mine doesn't, and never has.
Offline Mekaniko
« Reply #11 on: February 24, 2022, 12:21:52 pm »
Well yours is black... but I think that is not normal too.
Mine is doing it since at least 3 years ago and still running perfect.
  • -Receive: 692
« Reply #12 on: February 24, 2022, 03:45:26 pm »
You can still see soot and oil spotting on a black car..... especially when it's dirty.
Offline LC5F
  • -Receive: 80
« Reply #13 on: February 24, 2022, 07:48:42 pm »
What's your oil consumption like?
Mine used to chuck out a lot of soot and I could see in the mirror on hard acceleration a plume of stour/dust coming out the exhaust. Tail pipe and bumper sooty.
Mine had high oil consumption, changing to thicker oil helped but still high, double the recommended at 2 litres per 1k miles - eventually pinned this down to blown oil seal in the hot side of the turbo.
Now I barely have any soot on the exhaust & oil consumption has quartered.
Offline FatWelshBoy
« Reply #14 on: February 24, 2022, 07:56:20 pm »
Perfectly normal, mine does it and when I've had a look at other cars they are the same.
