Author Topic: Centre Caps  (Read 2057 times)
Offline ttelracs
Centre Caps
« on: July 07, 2022, 09:45:25 pm »
I've bought 65mm one twice and had to send them back since they didn't fit as the centre hole would break off one of the tabs.
I then bought 55mm and they were too small. What am I doing wrong?
I just looked up the part number and the one I got is 3B7 601 171. Maybe my 18 inch Monzas are reps and I need to find another option.
Offline mjmallia
  • -Receive: 60
Re: Centre Caps
« Reply #1 on: July 08, 2022, 08:13:11 am »
Take one of your caps off and note the dimensions to compare to what is on sale.
I have used aliexpress for wheel badges in the past, and there are usually lots of dimensions included too.
Mike
South Coast
Offline GreigC
Re: Centre Caps
« Reply #2 on: July 08, 2022, 01:41:29 pm »
Remove one of your alloys. Check if there is a VW part number on rear. If not they are reps and you would need to measure the existing caps and try get closest to it.
Offline ttelracs
Re: Centre Caps
« Reply #3 on: July 12, 2022, 11:25:09 pm »
It came without caps at all.
I'll did out the micrometer and get measuring.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: Centre Caps
« Reply #4 on: July 13, 2022, 02:37:16 pm »
The inside mounting diameter should be 56mm. The outside cap diameter should be 66mm.
If 3B7 601 171 (XRW or BXF) is falling out, then yes...git to measuring the wheel.
