Author Topic: ABS fault (01130) and module replacement  (Read 2538 times)
Offline Nertballs
« on: March 09, 2023, 02:05:06 pm »
Hi all,
So I've gotten the 01130 fault code and accompanying christmas tree dash board. I checked all the fuses (all okay) so I'm going to have to change the pump/module.
My car (mk5 GT TDI 140 DSG) has the 1K0 614 517 BE pump, and I've been tearing my hair out trying to find a replacement that isn't crazy money. Are there any other versions that will drop in? I have VCDS so can do the coding side, just making sure I'm getting the right pump is the main concern.
Thanks in advance!
Offline bobby_fodge
  • -Given: 22
  • -Receive: 39
Re: ABS fault (01130) and module replacement
« Reply #1 on: March 09, 2023, 03:49:38 pm »
It's definately not the wheel speed sensors?
Offline Nertballs
« Reply #2 on: March 09, 2023, 04:53:43 pm »
No codes were coming up for a specific wheel sensor, just 01130, then 008 - plausibility fault.
Offline Nertballs
« Reply #3 on: March 31, 2023, 01:30:55 pm »
I've managed to get a hold of an almost identical pump/module:
1K0 614 517 BG
Anyone know if there's any different wiring connections I should be aware of? I've looked up but can't find any details. I know I'll need to do the long coding but just wondering if there's anything else to keep an eye out for.
Offline Nertballs
« Reply #4 on: April 06, 2023, 10:52:06 pm »
Just an update to this in case anyone is chasing down a replacement pump, I fitted the BG pump today and got it working fine.
Straight swap on the units themselves, no issues with connectors. I had copied my coding from my previous pump before removal. When I connected to the new pump I was getting the DTC "Incorrect Control Module", so I went into the long coding section, turned off hill hold (new pump didn't have it) and cleared the code, all good.
After the coding I did all the required adaptions, and did the vagcom brake bleed. The dash lights don't go off until you drive the car, so got that done and I now have ABS again after 4 months! Just need to get through the NCT now.
Would've liked to keep Hill Hold, but was struggling to get the right pump so a working replacement unit in for 100 quid and I'm happy enough.
