Author Topic: coolant flush  (Read 2860 times)
Offline blingsta
coolant flush
« on: March 13, 2023, 01:25:30 am »
hi all
i want to do a coolant flush...  whats best way? - rad bottom hose or the aux water pump near the sump?
https://www.myfastgti.com/threads/coolant-flush-diy.17420/
would the aux water pump be ok to flush from?
Offline GVK
  • -Receive: 75
    • GVKmotorsport
Re: coolant flush
« Reply #1 on: March 13, 2023, 07:40:51 pm »
Can't see a problem doing it from aux pump
Offline blingsta
Re: coolant flush
« Reply #2 on: March 13, 2023, 11:00:59 pm »
Would that empty the whole system?  Is it the same as doing it from rad bottom hose?
Offline GVK
  • -Receive: 75
    • GVKmotorsport
Re: coolant flush
« Reply #3 on: March 14, 2023, 08:04:39 pm »
It's as low a point in the coolant system so can't see a problem in doing it from there - probably easier than getting the bottom hose off.
Offline blingsta
Re: coolant flush
« Reply #4 on: March 15, 2023, 11:47:37 am »
Yes it is  :signLOL:
i'll try it and see what happens  :happy2:
thanks for reply
Offline blingsta
Re: coolant flush
« Reply #5 on: March 24, 2023, 02:16:43 pm »
Just a quick update .
i managed to flush the cooling system from the lowest part - (aux pump) which was sooooo much easier than getting that rad bottom hose off !!  :partywave:
anyways..   all flushed n cleeeean now  :jumpmove:
Offline Valztattmk5
  • Newbie
Re: coolant flush
« Reply #6 on: January 02, 2024, 05:01:52 pm »
Hey ! Just done a coolant change on mk5 1.9 tdi, undone the bottom rad hose and maybe 2/3 litres off old coolant came out , I was expecting 8 litres ? I’m guessing that’s not a complete flush then and the remaining 5 ish litres would be sitting in the engine??? Any help would be much appreciated
