Author Topic: subframe  (Read 9171 times)
Offline 9MAK
  • My Ride: ed30
subframe
« on: August 15, 2023, 08:08:27 pm »
Hi, ive ordered a tyrol sport subframe kit and was wondering what other bolts i need ive seen some people saying you need audi bolts is this correct? if so please could someone list the part numbers cheers.
Offline terrier
  • -Receive: 41
  • My Ride: GTI now gone
Re: subframe
« Reply #1 on: August 16, 2023, 02:12:46 pm »
I replaced all the subframe bolts when installing the 034motorsport deadset kit
 LOADS of guides out there  Torque wrench is a must
http://www.tyrolsport.com/files/forumpics/Deadset_installation_instructions_revised.pdf
https://www.golfmkv.com/forums/index.php?threads/important-clunk-creak-front-suspension.51720/
  • -Receive: 692
Re: subframe
« Reply #2 on: August 19, 2023, 12:25:03 pm »
Tyrol provide a pair of ARP bolts with the kit for 2 of the collars.  The rest of the bolts just use new standard GTI ones.  And do replace them as stretch bolts must not be reused.  If you really must reuse them (bolts are expensive these days, I get it), just torque the 18mm ones to 100nm and the 16mm ones to 70nm. Do not redo the 90 degree angle!
« Last Edit: August 19, 2023, 12:26:49 pm by Pudding »
