Author Topic: Boost leak ?  (Read 2753 times)
Offline JakeyGhost
Boost leak ?
« on: October 30, 2023, 07:46:02 am »
Hi, I'm wondering if anyone has had similar symptoms and managed to get their problem sorted?
I have a MK5 GTI, which has slowly developed a boost leak that has gotten worse over time.  Very loud gushing when pulling away or ar low revs.  Today it seemed like the turbo was spooling up although there was a big loss of power intermittently then back to normal once enough pressure is built up the leak seems to plug itself back up and the problem seems to go away.
I have searched and not found anything related to my issue.  Any help would be appreciated.  I have changed my intercooler pipes, brake boost pipe and booked in to have the intercooler changed on Wednesday.  I will keep you updated.
Offline Billybear27
  • Newbie
Re: Boost leak ?
« Reply #1 on: October 30, 2023, 04:51:48 pm »
Hello, check the pipes going into the vacuum pump, make sure there not cracked or split and check you PCV valve, also a bad diverter valve can be the cause of a boost leak if the rubber in the valve has split, do you have a engine light on? i had a split pipe going into the vacuum pump and got a p0171.
Offline SANDEGTI
Re: Boost leak ?
« Reply #2 on: October 30, 2023, 06:36:33 pm »
First point of call is to check the diverter valve and if you haven't replaced it before do it anyway. Then I'd check the PCV, then all the connecting boost pipes and look for any splits, cracks or if something is loose in general.
Had all three fail on mine, I only did the PCV myself though. I had a rocker cover leak too.
Stage 2+ 2005 Laser Blue
Offline JakeyGhost
Re: Boost leak ?
« Reply #3 on: November 09, 2023, 05:54:04 am »
I have changed the pipe on the vacuum pump, currently running a forge DV which I am going to swap for a OEM+.  I do not have any oil leaks or spillage to suggest the rocker cover is blowing.  I have a smoke test booked next week, I will post updates here
Offline SANDEGTI
Re: Boost leak ?
« Reply #4 on: November 09, 2023, 07:03:45 pm »
Rev G has been the best for me. I'd replace half of this stuff anyway as precaution.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: Boost leak ?
« Reply #5 on: November 11, 2023, 02:44:52 pm »
If the issue periodically goes away, I would be suspicious of a valved system connected to the inlet manifold; having a sticky valve. The EVAP, PCV, and brake booster all have one-way valves to separate those systems from the inlet manifold pressure; when boost is present. Those valves are open and allow those systems to utilize the vacuum, when in vacuum. But those valves will be shut, by the pressure of boost, to isolate boost pressure (when present) to the manifold. Perhaps, from how you described it, a valve is hesitating to shut. And when it finally does, it goes back to normal. Someone doing the upcoming smoke test, if they are familiar with it all, should be able to thoroughly test it for you.
« Last Edit: November 11, 2023, 06:38:23 pm by ROH ECHT »
Offline K03MK5
Re: Boost leak ?
« Reply #6 on: November 11, 2023, 09:31:11 pm »
FMIC Clips have possibly popped off.  Mine had a similar issue last week (no boost).  ATS replaced clips for free as the FMIC wasnt fitted correctly by previous mechanic.  Top lads....
« Last Edit: November 11, 2023, 09:36:57 pm by K03MK5 »
