Author Topic: Turbo Oil Feed Return Pipe VW Golf MK5 And gasket  (Read 2317 times)
Offline K03MK5
« on: December 25, 2023, 08:32:15 am »
Hi,  Can anyone help with the genuine part numbers for a gti mk5 Turbo Oil Feed Return Pipe and turbo gasket?
Thanks.
« Last Edit: December 25, 2023, 09:19:06 am by K03MK5 »
Offline OllieVRS
  • -Given: 17
'06 Skoda Octavia vRS TFSI
Offline OllieVRS
  • -Given: 17
Re: Turbo Oil Feed Return Pipe VW Golf MK5 And gasket
« Reply #4 on: December 25, 2023, 11:40:36 pm »
Hi,
Is this it?
https://www.ebay.co.uk/itm/285607621942?hash=item427f8a7536:g:VFkAAOSwQpJle189&amdata=enc%3AAQAIAAAA0LD4%2FjZRwG4wy2ATCVzGt3Wd5%2Bs0Uek21lHCiA9ob47uefuBc85PflgKXAyUmJ%2Fcum082efEQho4nYq2lmeWrBHe%2BFAcpPmVAnpx0w5uCXrqe9gtXOenVnPJo3AX%2FaEcUx24J%2BO0dnLsWu22oirV3Ut1Qzes91VFFIzaPEB6X8zsg4QvywM2G7luWFumsU9If3U%2FgjxdU9gQ0AZX6jEj6aFXkgH88IK9%2BEAuMzsXthOGQBm2c4TTFszTb4r%2F70RCobjyaR%2B43S9wfYlCwg%2FTuAw%3D%7Ctkp%3ABk9SR5Tamp-UYw
Dont particulary want to use used.
cheers
depends, are you talking about the return line that connects directly to the sump? Then maybe this one, hard to tell because the ends are covered. The non turbo end should match the gasket shape I sent earlier.
I'm thinking this is it:
https://www.ebay.co.uk/itm/256244596972?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D258479%26meid%3D17732814495244a69c4716bd6247b5ac%26pid%3D101196%26rk%3D2%26rkt%3D12%26sd%3D186145611090%26itm%3D256244596972%26pmt%3D1%26noa%3D0%26pg%3D4429486%26algv%3DSimplAMLv9PairwiseWithPLXWebFitmentFilterConfirmFitSignalV2%26brand%3DOE%252B&_trksid=p4429486.c101196.m2219&amdata=cksum%3A25624459697217732814495244a69c4716bd6247b5ac%7Cenc%3AAQAIAAABMPYpaD8nYPH81DuZHNSX7lkZ7%252Fj5mtRzXG6BtgnQ878e7BDosKQZZxEbE6miQX5LMoNqGWl4um1MkbSEJd3Z3wSmejPqUpnufMq4uaygXIVozekMF8v%252B%252Fk8vc2EfxrzIdQA408Lb3Lbhd0rqXsLqQ0BI1yRkejjJS0tH07J6Mn6jQp3lNqsz3bu0jeiePhpLr7nMeLk%252FpJr6ANTcRdRIovgJOaAZDAVZxXMmXgYrsUjenC9TYHXYz%252BNJCUSFcGyVw9HSdMgOWhnxgt39MT2zyYIB8HlrZ%252FXu756m5knot7riywfgvrgJ8Ny84ihHgMHiyPLbfLoqOQgOWGwBsPV2JWujjDxLKbxuQaORpZf43Ra3FNt6IErAEwHDKe3hEIHoXptOQB9VwX7VKA8j5U92KGY%253D%7Campid%3APL_CLK%7Cclp%3A4429486
definitely not this one if we're talking about the same thing.
Offline OllieVRS
  • -Given: 17
