Author Topic: Mk5 Headliner Replacement - Suggestions  (Read 17298 times)
Offline g7jhp
« on: April 18, 2024, 09:39:26 pm »
The headliner on my 5 door Mk5 (non sunroof) has separated from the foam backing and now hangs from the front centre panel, rear centre light panel and back.
I've watched the video and will probably drop the headliner, clean it off and re-glue some new fabric and reassemble.
Having measured I think circa 140cm (wide) by 200cm (length) should be fine, but may go for 300cm.
Can anyone recommend where I can get a black headliner fabric which is like OEM?
Offline ZoliWorks
Re: Mk5 Headliner Replacement - Suggestions
« Reply #1 on: April 19, 2024, 06:25:41 am »
This is where I'm getting mine from when I'm redoing my interior. They also have alcantara with 2 sided tape already applied to it which is much easier but I'm going for that OEM look. Don't go full black, go anthracite, it doesn't look good.
https://sekerciotokumas.com/en/product/lakost-headliner-fabric-anthracite/
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Milltek Catless Resonated Exhaust | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
« Reply #2 on: April 19, 2024, 10:00:44 am »
