Author Topic: Does the Oversized Ramair Intake require oiling?  (Read 6065 times)
Offline SANDEGTI
« on: May 15, 2024, 07:40:10 pm »
So I've been wanting to clean my air intake for a while now, it's way overdue and now it's sunny I'm wanting to do these jobs.
From what I remember the instructions didn't include re-oiling the filter after cleaning? But now I've seen videos on YouTube state that they need re-oiling, while others are saying not to do it at all.
Cheers guys. :drinking:
Stage 2+ 2005 Laser Blue
Offline ZoliWorks
  • -Receive: 31
Re: Does the Oversized Ramair Intake require oiling?
« Reply #1 on: May 16, 2024, 07:05:12 am »
Depends entirely on the filter. If it's a paper filter, straight up replace it with a new one. If it's more cloth-like, probably wash it and oil it if it had oil included in the package or the manual says so.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Ta-Technix Cat-less Downpipe | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
Offline Jons1001
  • -Given: 22
« Reply #2 on: May 16, 2024, 11:04:27 am »
I've got the oversized Ramair and buy the ramair cleaning kit which is a cleaner and oil (i did research if another cleaner would be ok but couldn't get a definitive answer). So you use all the cleaner and then a light misting of oil which means you end up with nearly a full bottle of oil left over, but you can't buy them separately so just end up with loads of oil left over each time, bit of a waste really.
Offline OllieVRS
  • -Given: 17
« Reply #3 on: May 16, 2024, 08:39:55 pm »
Yes. They even sell their own cleaning kit.
'06 Skoda Octavia vRS TFSI
Offline GVK
  • -Receive: 72
    • GVKmotorsport
« Reply #4 on: May 16, 2024, 09:24:07 pm »
Don't put too much oil on them, you don't want to saturate the maf sensor.
