Author Topic: Temp gauge dropping when heaters on  (Read 4946 times)
Offline R88TTD
  • Newbie
« on: November 29, 2024, 12:29:34 pm »
Hi guys
I started experiencing new problems with MK5 gti
The temperature gauge drops from 90 to 75 then 50 gradually as soon as I turn my heaters on
Now the heaters are blowing hot air as normal
I asked about and some tell me the battery , some tell me the temp sensor and some are telling me the thermostat, water pump was changed about 15k miles ago so that ruled out
No head gasket issues , no over heating
Just wondering if anyone had this issue before Thanks
Offline ZoliWorks
Re: Temp gauge dropping when heaters on
« Reply #1 on: November 29, 2024, 03:55:04 pm »
If you want to find out if it's the thermostat or not, go on the highway, drive at a constant 130-140kph without the heater and see if the temp drops. If it does, it's the thermostat.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Ta-Technix Cat-less Downpipe | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
Offline Octoparrot
  • -Receive: 104
« Reply #2 on: November 29, 2024, 04:39:27 pm »
I'd put my money on the thermostat.
Offline mjmallia
  • -Receive: 58
« Reply #3 on: November 29, 2024, 06:18:03 pm »
Thermostat for sure
Mike
South Coast
