Author Topic: Intermittent DSG Whine  (Read 6741 times)
Offline lazy
« on: March 09, 2025, 11:46:04 am »
The noise sounds like a dry oil pump whine. It used only happen rarely when stuck in traffic for a while and if I put it in neutral it would go away. It's now happening more frequently and also sometimes when I'm driving. I was thinking about changing the oil pump but I'm not 100% sure it's that. I've trawled Google and can't find a definitive answer to whether the oil pump is only driven when in drive not neutral. There's no oil leak so I'm sure the oil level is right as I serviced it myself about 6 months ago. Has anyone else had anything similar to this happen to theirs.
Offline mjmallia
  • -Receive: 59
Re: Intermittent DSG Whine
« Reply #1 on: March 10, 2025, 09:00:01 am »
I assume you changed the filter at the time of the DSG service and not just the oil?
Mike
South Coast
Offline lazy
« Reply #2 on: March 11, 2025, 08:10:44 pm »
Yeah, I used genuine oil and filter.
The traffic tonight and last night was quieter and it didn't do it.
Offline lazy
« Reply #3 on: April 06, 2025, 09:16:30 pm »
I might have been barking up the wrong tree with the gearbox. The last two times it's made the noise I switched the Aircon off and it stopped, so I'm thinking it's the Aircon compressor now.
Offline mjmallia
  • -Receive: 59
« Reply #4 on: April 07, 2025, 07:49:44 am »
Set the tensioner to its locked position and check the other pulleys available.......but you appear to have possibly found it.
Mike
South Coast
Offline lazy
« Reply #5 on: April 07, 2025, 10:36:55 am »
Putting it in neutral and the noise goes away really threw me out. I was definitely thinking the worst.
Offline GreigC
« Reply #6 on: April 07, 2025, 09:55:41 pm »
Most likely the flywheel. A video would help if the mic can pick it up to confirm. Mileage?
Offline lazy
« Reply #7 on: April 09, 2025, 08:44:22 pm »
The mileage is just on 80k. Because it's so intermittent and random I haven't been able to actually get out of the car when it's doing it, to try and locate it. It always seems to be at traffic lights and never when I'm parking up. If it does it and I'm able to get a video I will.
