Poll
Does anyone have explanation of why is my block 93 in VCDS -6 after everything was replaced?
My timing chain and tensioner are bad.
0 (0%)
My variable variator is faulty.
0 (0%)
Total Members Voted: 0
Author Topic: Golf MK5 GTI block 93 -6 degrees after everything was replaced recently  (Read 6425 times)
Offline gmazjunior
Hi, I have a problem. To begin with I have a MK5 GTI, which has a problem that i thought i fixed. I changed my cam chain,cam chain tensioner, timing belt, timing tensioner, rollers and water pump but haven’t changed variable variator. When all that was changed my block 93 on VCDS was -3 and then -2. All this was in January this year. Today, i checked my block 93 again, 4000 miles later and my block 93 was at -6? Forgot to mention, that i changed VVT solenoid too.
Offline MKVASMR
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php/topic,134365.msg1165175.html#msg1165175
Check channel 91, maybe you've skipped a tooth on the timing belt side and the chain is compensating. If you are sure about the timing and you se a large deviation on 91 then you didn't set the tensioner right.
Offline gmazjunior
If specified is 24 it varies from 23 to 25 sometimes but usually only about half degree.
Offline MKVASMR
Unplug the variator and check the values again. Make sure that the engine is running at operating temp. and it's on idle.
Offline gmazjunior
You mean the solenoid?
Offline gmazjunior
I unplugged the VVT solenoid, let the check engine to turn on idle and then it was at -7????!!!!! How???
