Author Topic: Timing belt and chain change interval  (Read 2359 times)
Offline bojan.u
  • Newbie
« on: April 15, 2025, 02:51:23 pm »
Hello, I bought gti mk5 and it has 100kkm after timing belt replacment. So after 100kkm its time to change timing belt set + water pump. Does the chain and tensioner also need to be replaced at this interval (100,000 km)?
Regards,
Bojan, Slovenia
Offline Jons1001
Re: Timing belt and chain change interval
« Reply #1 on: April 15, 2025, 08:18:45 pm »
Hi yes I think the belt is 4 years or 100,000km whichever comes first.
Chain you can check if you have VCDS or OBDeleven to see if it is within tolerance. Mine is on 145k miles on original chain.
Offline mjmallia
  • -Receive: 58
« Reply #2 on: April 15, 2025, 08:26:38 pm »
It is worth doing the chain and while your there the tensioner and phase adjuster with new rings. The phase adjuster gets worn and gets grooves cut into it which reduce the oil pressure to it. That and the tensioner getting lazy, the chain naturally stretching over time can create havick and warning noises/rattles. A lot of people including myself have been there.
I did the lot as preventative mintenance and the engine ran better and quieter.
« Last Edit: April 15, 2025, 08:30:41 pm by mjmallia »
Mike
South Coast
Offline mjmallia
  • -Receive: 58
« Reply #3 on: April 15, 2025, 08:31:31 pm »
Timing belt i religiously change every 4 to 5 years.
Mike
South Coast
Offline Jons1001
« Reply #4 on: April 15, 2025, 08:38:00 pm »
Hi, is there a trick to doing it without rounding the VVT adjuster bolt thingy? And is it still a £300 plus part? Cheers
Offline mjmallia
  • -Receive: 58
« Reply #5 on: April 16, 2025, 09:28:34 am »
I made a post on how I did it somewhere.
EDIT: https://www.mk5golfgti.co.uk/forum/index.php/topic,134480.0.html
I used the INA phaser, chain and tensioner with genuine bolt and the lot cam to about £300 in total.........new gaskets also.  The OEM phaser the last time I checked a few months ago was £560 +VAT (£672) as usually always go genuine........but the genuine tensioner is made by INA for example. Genuine parts equiv came to about £1000 odd in total, which is why I went OE next level down with INA who also make most of the parts anyway.
Mine has been perfect since changing it all myself.  I used an impact on the bolt to begin with, to help break the metal on metal bond then a breaker bar and it came off with ease  :innocent:
« Last Edit: April 16, 2025, 11:53:31 am by mjmallia »
Mike
South Coast
