Author Topic: Headliner Material  (Read 15111 times)
Offline Gull
Headliner Material
« on: June 25, 2025, 10:08:42 pm »
Hi folks!
I managed to salvage my old headlining which has lasted a little while but the dreaded sag is stating to appear around the glasses holder.
Has anyone (recently) found an OEM quality fabric which matches the pillars for a replacement headlining? I'm certain I saw someone doing a really good replacement but I can't find the post and the search only comes up with pretty old threads :(
Any suggestions would be most welcome!
Thanks,
Gull
Offline slipd
Re: Headliner Material
« Reply #1 on: June 30, 2025, 07:21:05 am »
Interested in this too. My headliner has almost entirely dropped now and detached from the foam backing...
« Reply #2 on: June 30, 2025, 08:07:25 pm »
https://www.facebook.com/share/1HLHGCoWyp/
Speak to this lady who does them
Offline rxpx69
« Reply #3 on: August 01, 2025, 05:08:46 pm »
I've been down the rabbit hole as i need to do mine soon, from what i've found the fabric material is called 'SunBrite' and you'll need it in Charcoal Black (SB2469) for a GTI.
https://www.uphsup.com/p-7668-sb2469-2469-flat-knit-headliner-charcoal-black-60-316-sunbrite-per-yard.aspx
I've mostly found American sites selling it, Good luck!
Offline slipd
« Reply #4 on: August 01, 2025, 06:21:04 pm »
Thanks for that! It looks like they have my grey material as well...
My liner is literally held up with pins atm :confused:
Offline rxpx69
« Reply #5 on: August 03, 2025, 12:07:50 am »
Post some pix if you go for it, would be handy to see what the fabric looks like in real life vs the original  :smiley: :happy2:
Offline Paul_nicol
« Reply #6 on: August 03, 2025, 09:02:34 pm »
Hi, I recently did my headlining, i'll get some pics. The material on the headliner is pretty different to that used on the pillars, I  used the arm rest / door cards as my point of reference. My research indicated that finding a fabric with a foam backing and had some stretch in it was key, doing around the horn of the overhead console is tricky and avoiding creases is quite challenging and without the stretch I'd be inclined to say impossible. I used Martrim to source my material, I grabbed a couple of samples, but for the life of me, can't find the order to confirm which material i ended up with! It's not OEM stuff, but  think it's a good match. https://www.martrim.co.uk/
Offline rxpx69
« Reply #7 on: August 06, 2025, 04:34:01 pm »
Well done! What headliner glue did you go for? I'm looking for a roll on glue as I feel the spray glue is messy and leaves gaps.
Offline Paul_nicol
« Reply #8 on: August 07, 2025, 10:09:30 pm »
I used Trim Fix High Temp. It is an aerosol, but was what Martrim recommended. Mess wise, it's fairly controllable, I did use 2 wallpaper pasting tables covered in some old curtains to catch the over spray. Your point about gaps could be valid, by and large it's not been a problem, but the bits where you have to stretch the material i.e. round the horn, in the grab handle resess has come unstuck, I don't think it is through a lack of glue (used 2 cans), more about the strength of the glue, thankfully it doesn't look too bad as it's hidden by the handles and the bit around the horn is the same both sides, the rest of the headliner has gone on really well and held up to the insane temps we've had.
I used this YouTube vid to get a good idea of how to approach it.
