Author Topic: Air con not working - does the compressor stop working if sensor is dodgy?  (Read 5934 times)
Offline dave1814
Hi guys,
For anyone that's had a bad high pressure sensor issue, did you compressor still spin in the center or does the car automatically cut it off to protect it?  Mines not spinning when the aircon is on.
I've got the error...
00229 - Refrigerant pressure.
002 - lower limit exceeded.
thanks!
Dave
Offline GVK
  • -Receive: 75
    • GVKmotorsport
Pretty sure it doesn't run to protect the compressor.
Judging by the code you have a leak .
Offline dave1814
Thanks.
It's only just been regassed so I'm thinking it could be the sensor?
Offline GVK
  • -Receive: 75
    • GVKmotorsport
Replaced a few of them sensors back in the day so possible.
Of course depending on severity of leak it could be that too.
IIRC the sensor is 2 wire so try bridging it with a paper clip and see if comp. cuts in.
Offline dave1814
ah good call - ill try that before replacing
