Author Topic: Headliner Replacement - MK5 Golf GTI  (Read 13309 times)
Offline Husy
« on: July 09, 2025, 12:47:14 pm »
Hey folks, has anyone had their headliner replaced recently (MK5 Golf GTI) due to the common sagging issue? Would really appreciate any tips or recommendations for decent upholstery trimmers in the Sussex area. Cheers!
Re: Headliner Replacement - MK5 Golf GTI
« Reply #1 on: July 10, 2025, 09:41:13 pm »
Offline Flyingscotsman
  • -Given: 26
« Reply #2 on: July 11, 2025, 07:11:26 am »
I used this company recently. They did a nice job.
https://www.davethetrimmer.com/
Offline G-olf
« Reply #3 on: July 25, 2025, 09:38:46 pm »
I've replaced mine a couple of years back with a good one from a breakers yard. Its also now sagging so recently had the original board recovered by a local guy.
Currently waiting to fit it, the material is slightly lighter but a good match  :smiley:
Hopefully this will last longer :smiley:
Offline hcmzah
« Reply #4 on: July 26, 2025, 03:37:17 pm »
How much did that end up costing you?
Offline Husy
« Reply #5 on: July 26, 2025, 07:17:02 pm »
Hi, I received varying quotes ranging from £400 for an exchange and fitting, to around £550–£650 for a full retrim of existing headliner. Since mine has a sunroof, it might be slightly more expensive. There was also a DIY option available at £200, which includes supply replacement (returning your old existing headliner) and fit it yourself. It’s on my to do list to finalise which option to run with. Hope that helps.
Offline G-olf
« Reply #6 on: July 27, 2025, 04:20:47 pm »
Recover the existing board was £250
Complete job was £500 which includes removal re-trimming and refitting of the board.
I'm going to fit mine myself when I can get chance  :smiley:
There are some aftermarket boards available now
The Anthracite headliner from VW is now discontinued and not available
I'm told The mk6 board is exactly the same shape
Mk6 gti/gtd etc grey colour is a lot darker almost black but are still available to order from VW
Offline rxpx69
« Reply #7 on: August 01, 2025, 05:04:53 pm »
I've been down the rabbit hole as i need to do mine soon, from what i've found the fabric material is called 'SunBrite' and you'll need it in Charcoal Black (SB2469) for a GTI.
https://www.uphsup.com/p-7668-sb2469-2469-flat-knit-headliner-charcoal-black-60-316-sunbrite-per-yard.aspx
I've mostly found American sites selling it, Good luck!
