Author Topic: Mk5 drivers door lock issue. Ive tried everything.  (Read 7596 times)
Offline Fckfvd
  • Newbie
« on: July 12, 2025, 02:56:55 pm »
Hello guys, im new here. I brought a edition 30 cheap 3 years ago that needed engine work. All done, runs a dream. A month or so ago my drivers door lock stopped working.
Ive been a mechanic for 10 years and this one has got me stumped.
I know mk5s are notorious for door lock problems and was well aware of the normal faults. My drive door no longer locks or unlocks from the remote. It also doesn't recognise if the drivers door is open or closed.
Ive replaced the door lock actuator, first fitted a cheap ebay one this didn’t fix it so replaced with a tps genuine one, still the same.
Rewired the entire door loom -this didnt change anything so replaced it with one off a working car. fitted the loom i made to the other car which works fine on that vehicle.
Swapped the door module (window motor) with a known working one. Again no difference. Made sure the part numbers of all replaced part were correct they are indeed.
I dont have access to vagcom but do have a bosch kts.
Fault codes
0610- drivers door lock motor electrical fault
0060- drivers central locking fault in circuit
03a0- drivers lock position signal implausible.
Passenger door and boot. Lock and unlock perfectly and vehicle recognises if they are open.
Fuse is fine.
I have tested for voltage at the plug and i have voltage at the door lock plug. However when you actuate the key theres no switching or change. Everything else on the drivers door work. Ie, fuel flap and window and door lock boot.
ANY IDEAS?
Ive looked at wiring diagrams and nothing looks wrong. The only thing that did happen recently is i lowered the window fully once and it suddenly said my door was open? I closed the window and its not done it since.
Any ideas would be really appreciated.
Offline maxamplitude10
  • '07' ED30 Manual 3Dr
Re: Mk5 drivers door lock issue. Ive tried everything.
« Reply #1 on: August 17, 2025, 04:14:02 pm »
Have you tried disconnecting negative battery wire and leaving for 30mins before reconnecting. This solved my door lock issue.
Also I've read about turning key in ignition to "accessory" position and holding down the unlock button for 5secs?
No doubt you've prob tried this already!!
Good Luck
Max
