Alright im back with the logs including the lambda. I swapped back to the newer pump again and it seems to fit just fine now, dont know what i did wrong before..
https://log.tunezilla.com/s/0um1L1WtNow with all the swapped parts and the pump is fitted nicely in the tank hole the car threw some fault codes aswell. Makes sense but i think all the swapped parts were culprits aswell. The mesh filter in the old pump was completely clogged, tried soaking it in breakcleaner etc but made no difference. The car is drivable now but just a tad bit to much on the pedal it starts jerking. Im assuming the pump is pushed to 91% because of the nonsense values the g410 is giving the ECU.
4 Faults Found:
000307 - Oxygen (Lambda) Sensor B1 S1
P0133 - 002 - Response too Slow - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 133420 km
Time Indication: 0
Date: 2000.00.00
Time: 05:02:06
Freeze Frame:
RPM: 1417 /min
Load: 33.7 %
Speed: 57.0 km/h
Temperature: 73.0°C
Temperature: 41.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.716 V
012555 - Low Pressure Fuel regulation
P310B - 002 - Fuel Pressure Outside Specification - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 49
Reset counter: 255
Mileage: 133441 km
Time Indication: 0
Date: 2000.00.00
Time: 08:08:45
VCDS
Diagnostic Trouble Code Report
Control Module Part Number: 1K0 907 115 Q
Page 2
Freeze Frame:
RPM: 2116 /min
Load: 9.4 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 27.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.097 V
000135 - Fuel Rail/System Pressure
P0087 - 002 - Too Low - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 2
Fault Frequency: 32
Reset counter: 255
Mileage: 133454 km
Time Indication: 0
Date: 2000.00.00
Time: 06:54:39
Freeze Frame:
RPM: 917 /min
Load: 29.0 %
Speed: 0.0 km/h
Temperature: 29.0°C
Temperature: 20.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.843 V
009529 - Low Pressure Fuel Sensor (G410)
P2539 - 001 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 133749 km
Time Indication: 0
Date: 2000.00.00
Time: 02:58:22
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 31.0°C
Temperature: 38.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.938 V
