Author Topic: P2185 high-voltage circuit issue with the engine coolant temperature sensor 2  (Read 7991 times)
Offline jonnd
So check list i done so far.
My Aircon doesnt work atm need regasing,
Coolant wise i have had changed 4 sensors and 2 wiring harness and still nothing the only thing i havent touched is the fan controller on the fan which is working but come and off soon as i start the engine
Wiring i have checked ohms and beeper test all seems fine no break themo stat has been changed 2 times as well 2 differents engine and i still have the problem with P2185
Does anyone have any information or advice maybe a wiring dirgram so i can fully test all my wires
Could it be a blockage some where the coolant is getting to the sensor but is saying -45c on the vcds
Offline mabu769@gmail.com
  • Newbie
Hi how did you fix the problem I'm struggling with the same fault code please help
