Author Topic: MFSW and Highline cluster retrofit  (Read 261 times)
Offline Drekavac
  • Newbie
« on: Yesterday at 02:47:04 am »
Hello everyone, I own a mk5 golf that came standard with a 4 spoke and lowline cluster (not even outside temp, only milage and time lol). I bought a 1K0-959-653-C slip ring, 1K0-953-549-BD controller, MFSW and a highline 1K0-920-873B cluster. I installed the slip ring, controller and MFSW. Did the basic settings and some coding via vcds and everything worked fine for a couple of days. Then out of nowhere a steering wheel and esp light turned on. The wheel had no steering assist, was hard and wouldnt return back to the center on its own. After driving a bit the steering assist started working and the lamp went away, but esp remained on until i turned off and on the car. Now that issue happens randomly, sometimes during driving but most of the time when the car has been sitting for a while (like a couple of hours or overnight). During driving when it happens i can feel the steering assist coming back to life by a shake, like trying to return the wheel to center for a split of a second. I did do the basic settings when i replaced the slip ring, i tried loads of things but it keeps happening randomly. Did i do something wrong when installing? Did i miss something? I have no idea.
I did look up this issue and people said if the slip ring was bad then the MFSW buttons wouldnt work, but they do. At least the ones on the left to control the headunit. The ones on right dont cause i still havent installed the highline cluster. But thats a story for another time, gonna need to see what app i need to use to get it paired to the car lol
Offline mjmallia
  • -Receive: 59
Re: MFSW and Highline cluster retrofit
« Reply #1 on: Yesterday at 04:00:11 pm »
There are two types of steering wheel modules and the slip ring has to match the same type.
You need to work off the type that was originally fitted to the car.
https://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
Then the coding has to be done in one hit and in the order stated, as otherwise it just does not take for whatever reason.
Mike
South Coast
Offline Drekavac
  • Newbie
« Reply #2 on: Yesterday at 04:12:09 pm »
The original module was 1K0-953-549-A and slip ring 1K0-959-653. Is there an easy way i can confirm if got a wrong or faulty part? I was following the website when ordering stuff and got the highline module (1K0-953-549-BD) and type 2 slip ring (K0-959-653-C). I do have another slip ring i got for free with the steering wheel, but its from a passat 3C0-959-653-B so not sure that it will work
