Author Topic: BOV- Bad for car?  (Read 4277 times)
Offline B25SDJ
  • Newbie
BOV- Bad for car?
« on: February 06, 2026, 12:41:57 pm »
Ive been told that its not worth getting a blow of valve and i should just keep the recirc? whats the verdict? i want some nice noise from it. does it damage the car.
Offline GVK
  • -Receive: 76
    • GVKmotorsport
Re: BOV- Bad for car?
« Reply #1 on: February 06, 2026, 05:28:38 pm »
Because the car runs a MAF sensor based fuelling system, any unmetered air from an atmospheric BOV will upset the fuelling, could cause lumpy running and stalling.
Offline ZoliWorks
« Reply #2 on: February 09, 2026, 01:02:02 pm »
If you want some noise from it, stick an aftermarket intake, k04 dv relocation kit, a rev G dv and get it mapped. If mapped, you can use a DV+ if k03, rev G if k04. DV+ cant really deal with the pressure a K04 works with and will throw CEL
Also noise depends on the pressure the map demands of it.
First video was recorded with a k04 with a dv+ and 1.55 bar peak pressure. 2nd video is 1.45 bar peak and a rev G. The noise is still there just not as continuous. I have to be under WOT for it to happen. Also this was recorded when my downpipe-muffler buckle came apart so i was basically running a catless straight pipe
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Milltek Catless Resonated Exhaust | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
