Author Topic: Aftermarket speakers with OEM AMP?  (Read 2646 times)
Offline ZoliWorks
« on: July 12, 2026, 07:52:13 pm »
I have the factory 10-speaker system in my Mk5 Jetta, including the factory amplifier under the driver's seat and a RNS 510 head unit (retrofit).
The speakers are now almost 20 years old and a few of them are starting to fail, so I'm looking into replacing them while keeping the OEM amp and RNS 510 for the factory look/integration.
Has anyone had good results replacing the speakers while keeping the factory amplifier and head unit? I'm mainly interested in speaker recommendations that work well with the OEM amp.
My other Mk5 has Hertz Dieci speakers running off the stock head unit without an amplifier. They sound pretty flat compared to when I had an aftermarket head unit installed, which makes me think the OEM radio doesn't really like the 4Ω aftermarket speakers compared to the factory setup.
I'd prefer not to replace the RNS 510 or add an aftermarket amp unless absolutely necessary. Has anyone successfully upgraded the speakers in this setup?
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Milltek Catless Resonated Exhaust | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
Offline mjmallia
  • -Receive: 60
Re: Aftermarket speakers with OEM AMP?
« Reply #1 on: July 14, 2026, 08:07:31 am »
I have the 10 speaker system also and replaced all the speakers with Pioneer in the front doors and Kenwood in the back doors.  I did keep the original front door tweeters as they sounded better to me, but did leave the inline capacitor thinking about it when it was connected to the OE crossover.
Mike
South Coast
Offline ZoliWorks
« Reply #2 on: July 15, 2026, 02:31:04 pm »
Have you checked whether yours are 2 ohm or 4 ohm factory speakers? I haven't had time to check mine yet but if they actually are 4 ohm then I'm all set.
Offline mjmallia
  • -Receive: 60
« Reply #3 on: July 16, 2026, 11:31:50 am »
Pretty sure they are all 4 ohm
Mike
South Coast
