Author Topic: Power Steering  (Read 991 times)
Offline JackBMK5
  • Newbie
Power Steering
« on: September 09, 2026, 09:31:17 pm »
Hey all, new here. Recently purchased a MK5 GTI, I have an intermittent power steering issue. When the car starts up first thing, power steering works as should, after around 10-15 minutes, i get a beep (no warning light on dash just the sound) and then lose all power steering. Sometimes it will come back on temporarily during the drive, sometimes it stays off the entire time. Sometimes when I turn the car off and back on, it works again.
I have cleaned the earth connectors by the battery that are known to corrode. My two current thoughts on this is that when i bought the car, the wrong battery was fitted (incorrect amp) or that it is a problem with the rack its self.
Any thoughts are appriciated.
Offline Lightynolikey
Re: Power Steering
« Reply #1 on: September 23, 2026, 09:03:26 pm »
Ive heard the rack is hydro electric.
From the little experience with full electric its that part that heats up/stops working.
Plug it in and put fault codes here till someone clever will answer.
Dont drive it till fixed, not worth riskin your life at all.
Check the dash light comes on with the ign and not tampered with.
Sorry but ive limited electronics or comp diag experience.
