Author Topic: dsg problem  (Read 5243 times)
Offline Richn83
  • -Given: 49
  • -Receive: 86
Re: dsg problem
« Reply #15 on: April 12, 2010, 04:54:58 pm »
Yeah makes sense, is it just on 1st to 2nd shift?  The shifting on mine improves once the engine and gear box are up to temperature, which I suppose would suggest the oil could be contributing rather than the dreaded mechatronic, do you see the same behaviour?
Offline aidogti
Re: dsg problem
« Reply #16 on: April 12, 2010, 05:25:18 pm »
yeah its only between 1st and 2nd... not sure if it stops when gearbox temp heats up.... will keep an eye on that.. yeah hopefully its just in need of an oil change, just checked the service history there and theres nothing mentioned bout gear box oil change so hopefully thats the answer. thats the only prob im having, it selects perfectly through the other gears
Offline Richn83
  • -Given: 49
  • -Receive: 86
Re: dsg problem
« Reply #17 on: April 12, 2010, 06:05:56 pm »
I would be interested to know Aido next time you go on a long run.  You said your due a service soon, how soon?  I have a VCDS cable so I could try the DSG re-set as was suggested, but a little un-sure if I want to fiddle with the DSG settings if an oil and filter change is all thats required.
Offline kirkland
Re: dsg problem
« Reply #18 on: April 12, 2010, 06:22:50 pm »
hi lads,  i have a 2005 gti dsg and ive noticed there is a delay between 1st and 2nd in my car, its only noticable when in first and i accelerate quickly... i mainly drive it in D, any ideas lads on what the problem could be?
I have a feeling DSG may have decided sometimes to be 'ready' in 2nd gear in these circumstances & a sudden acceleration as you describe, can momentarily confuse it as to whether to drop a gear hence the lull.
Offline Timvgti
Re: dsg problem
« Reply #19 on: November 01, 2011, 08:06:18 pm »
Aidogti: did a dsg oil change and/or dsg reset/basis settings adaption do the trick eventually?
I guess I have the same problem over here-> http://www.mk5golfgti.co.uk/forum/index.php/topic,37013.0.html
