Author Topic: KW (-20mm) and 17's - possible?  (Read 5057 times)
Offline broke.
« on: January 13, 2009, 12:15:16 pm »
I am wanting to stay with 17's on my 05 GTI and not go the 18" route unless i have to. will i be ok for ground clearance with -20mm KW springs? I'm debating whether to buy them but problem is if they ground i'll have to go for 18's, and i'll have to get the sportlines (-30mm) don't want to buy 2 sets of srpings if i don't have to.
Hope thats all made sense  :happy2:
Offline The wheel man
Re: KW (-20mm) and 17's - possible?
« Reply #1 on: January 13, 2009, 12:24:16 pm »
There should only be about 3mm in difference between the 17" diameter and the 18" so your only sitting 1.5mm lower.  IIRC most on 18" find a 20mm fine.
So you should be OK!!
HTH  :happy2:
APR cat back, ECS Insert
Offline NEWEY
    • Flickr
« Reply #2 on: January 13, 2009, 12:31:59 pm »
im hoping to go around 40mm with kw v2 at the end of the year on 17" so im hoping it will be ok for clearence
TSR big turbo mk5 golf gti
Offline broke.
« Reply #3 on: January 13, 2009, 02:39:47 pm »
cheers guys  :happy2:
« Reply #4 on: January 17, 2009, 12:47:55 am »
I'm on V3's and with an OSIR front splitter and still okay for clearance (except multi-storey carpark ramps).
Offline broke.
« Reply #5 on: January 19, 2009, 03:16:30 pm »
brilliant pics mate, just what i wanted to see. 20mm looks just right with the 17's  :happy2:
« Reply #6 on: January 19, 2009, 04:25:39 pm »
....Huh? Thanks, but I'm not on 17's - I'm on powdercoated Smoked Chrome Monza 18's : -
Also, most people (I'm sad to say) setup their suspension primarily led by what it looks like and how low they think they can go.
I wish I had £1 for each time I've read about someone getting it not quite right (or horribly wrong!) and having to re-do it - Invariably by trial and error - It would probably have paid for my suspension. Sorry if I sound irritated but I think people are such fools if they ignore the importance of the setup adjustments and just go on the looks regardless.
http://www.mk5golfgti.co.uk/forum/index.php?topic=1457.0
8)
Offline broke.
« Reply #7 on: January 20, 2009, 08:55:45 am »
I can understand your views, but with all due respect i simply wondered if i would have clearance issues. to say ' I think people are such fools' is not really a comment that is warrented or needed. i asked for clearance advice with -20mm and 17's. you posted pictures of Varient 3's and 18's, huh? unfortunately i didn't mention going for looks alone, the fact i am going for 20mm KW springs would suggest that i have not gone for 'low as possible', as there are much lower available and quality has been a factor. hence opting for the KW's  :happy2:
« Reply #8 on: January 20, 2009, 04:54:52 pm »
You've misunderstood my post by taking it personally and I've misunderstood your post by interpreting your words to mean that you were primarily led by ride height and I was expressing merely my opinion in reaction.
No problem - It's easily done on internet posts  8)
Hopefully someone else will give you the answers you need.
Offline broke.
« Reply #9 on: January 23, 2009, 01:45:46 pm »
I've had the KW's fitted  :happy2: so far i've not seen any drop at all from standard GTI  :ashamed: which is annoying. Was hoping for a genuine 20mm but so far can't even see 5mm  :sad: anyone else got the KW's fitted?
Offline gazbutS3
« Reply #10 on: January 23, 2009, 04:24:25 pm »
tehy will settle with time, but I'd have thought you would have noticed some drop
« Reply #11 on: January 23, 2009, 04:27:38 pm »
broke - How does your car feel with the KW's? Different?
Offline broke.
« Reply #12 on: January 24, 2009, 05:55:29 pm »
car feels great, much firmer. to be honest i don't chuck the car round corners etc so not noticed a geat difference, but the difference i have noticed is all good. its settled a bit now and has dropped all round. not 20mm though  :sad:
