Author Topic: Worn brake pads?  (Read 3264 times)
Offline Boothy
Worn brake pads?
« on: May 14, 2010, 10:08:54 am »
When I got my new wheels fitted the other week I thought I'd check the pads to see how worn they were. If you look closely at the below photo they appear to have worn at an angle? Basically the pad edge closest to the hub is far less worn than the edge furthest away. Is that normal because from little I know about brakes it seems a bit weird? They work fine so no real issues in that department but I would have thought the pads would wear evenly?
If I were to replace the pads too what would be a good, road legal replacement and is it simple to change them myself?
Ta.
« Last Edit: May 14, 2010, 10:10:29 am by Boothmeister »
Offline Richn83
  • -Given: 49
  • -Receive: 86
Re: Worn brake pads?
« Reply #1 on: May 14, 2010, 10:25:08 am »
Mine seem to be wearing the same, with the outer most section having more wear than the inside section, im not sure if it hasnt lead to the following odd wear pattern on my disc which I posted up in this thread.
http://www.mk5golfgti.co.uk/forum/index.php/topic,14309.0.html
Mine have alot less wear left than yours too.
Offline Boothy
« Reply #2 on: May 14, 2010, 10:36:50 am »
Hmmm. Very strange mate? Don't think I've any unusual wear on the disc that I've noticed but then I don't know what I'm.looking at half the time :laugh:
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #3 on: May 14, 2010, 10:45:07 am »
will see if I can get a picture of mine over the weekend to show the same wear, thinking of attempting the brake change, doesnt seem to hard in haynes manual apart form the possible issue with retracting the piston.  Just need to make sure I get some decent pads, and the right fitting kit incase I break the pins etc.
Offline PDT
  • -Receive: 142
« Reply #4 on: May 14, 2010, 02:21:24 pm »
The pads are made that shape!  its 100% normal
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #5 on: May 14, 2010, 02:26:19 pm »
Good to know PDT  :drinking: if I were to change the pads, should I get the proper tool to wind the pads in, or is there a simply way of bodging it with some other tools and a bit of brutte?  :laugh:
Offline GE90
« Reply #6 on: May 14, 2010, 04:19:51 pm »
As PDT said, this is normal. I think is provides some form of ‘lead’.
Front do not require a caliper wind back tool, but the rears would.
Cheers!
Offline Boothy
« Reply #7 on: May 14, 2010, 05:33:48 pm »
Good stuff!
