June 23, 2026, 01:04:33 am
All Things Mk5
Mk5 General Area
Anyone with a Mk5 GTi/ED30 with Eibach springs?
Topic: Anyone with a Mk5 GTi/ED30 with Eibach springs? (Read 2647 times)
PDT
Just look at my post count
-Given: 3
-Receive: 142
May 20, 2010, 08:07:16 pm »
If so, and you have 5 mins and a tape measure handy, could you do us a big favour and measure the gap from the centre of the wheel (front and back) to the arch lip in a straight line (90 degrees to the floor) and post these measurements in CM.
Car needs to be on a level surface as well
MAT ED30
-Given: 25
-Receive: 82
Vwr fan boy
Re: Anyone with a Mk5 GTi/ED30 with Eibach springs?
Reply #1 on:
May 20, 2010, 08:15:02 pm »
look at mine when i fitted sportlines
http://www.mk5golfgti.co.uk/forum/index.php/topic,191.30.html
PDT
-Given: 3
-Receive: 142
Reply #2 on:
May 20, 2010, 09:27:47 pm »
That helps a lot, would appreciate a measurement from centre of wheel to arch if someone could get me one, trying to resolve a problem on a customers car.
gazbutS3
-Given: 52
-Receive: 55
Reply #3 on:
May 20, 2010, 09:50:57 pm »
I've had a problem with Eibach springs in the past causing a real difference in ride height front to rear, at first we thought it was the Koni FSD dampers, and Koni even re-valved the rears to cure it and it turned out it was a bad batch of Eibach springs that was lifting the rear
thats not to say I think Eibach are a bad spring, quite the opposite to be honest
Last Edit: May 20, 2010, 09:52:43 pm by gazbutS3
JPC
-Given: 93
-Receive: 111
Reply #4 on:
May 20, 2010, 10:40:12 pm »
ill do it in the morning "skeg" ;)
All Things Mk5
Mk5 General Area
