Author Topic: Front wipers won't shift to change blades  (Read 2470 times)
Offline Nickyboy
  • 2007 ED30 in Grey
« on: May 22, 2010, 04:14:25 pm »
They used to, now I can't get them to move to the 12 o'clock position to change the blades.
Any ideas?
Cheers.
Re: Front wipers won't shift to change blades
« Reply #1 on: May 22, 2010, 04:22:35 pm »
Are you doing it right?
Turn ignition off, pull out key, hit wiper stalk downward once.
I know someone else who had issues with this so have a search.
Offline Nickyboy
  • 2007 ED30 in Grey
« Reply #2 on: May 22, 2010, 04:26:03 pm »
Downwards, upwards, ignition on, ignition off...nothing  :confused:
« Reply #3 on: May 22, 2010, 05:20:35 pm »
Did you pull out the key?!?!
Offline Nickyboy
  • 2007 ED30 in Grey
« Reply #4 on: May 22, 2010, 05:22:03 pm »
Yes.
I've put the wipers in the 12 position by using the wiper sweep with the key out, instead of pushing the wiper.
Offline Baz300
« Reply #5 on: May 04, 2012, 12:08:32 pm »
Found this through search! Thanks was sat in halfords car park trying to figure out how to change the wipers
Offline Nickyboy
  • 2007 ED30 in Grey
« Reply #6 on: September 27, 2012, 03:12:13 am »
It sometimes works pushing the wiper blade itself, upwards. Only when it wants to though
Offline apples12
« Reply #7 on: October 06, 2012, 09:33:14 pm »
with the car running push the stalk all the way down to get a single intermittent wipe...
switch the car off and straight away without doing anything else push the stalk down again for another intermittent wipe - your wipers should move to the 12 o'clock position (you can take the keys out but i've never done this - i usually do this when taking it for a wash n leave the keys in the ignition)
MK6 GT TDI  - CW - LUX pack
GONE
MkV Golf 1.9TDI Sport in DBP, 160,000 miles and climbing!
Retrofits by me:GT front end,OEM bixenons with auto-levelling/washers, Valeo LED Rears, MFSW + Highline SWCM, Cruise Control, 30byte Highline CECM, Highline clocks, Rain/Light Sensor, Auto-dimming Rear view Mirror, RNS-510 LED (Ver H; SW: 4020), Fiscon Basic Bluetooth, MDI + Aux, Armrest, Reverse Camera LOW, TPMS..what next...
Offline chrisr763
  • -Receive: 62
« Reply #8 on: October 08, 2012, 01:19:03 pm »
Taking the key out has no affect, and trying to turn the ignition off before the wipers return 'home' also doesnt help as they do this automatically.
The only way to do it is ignition on, off and wiper down once.  :happy2:
Offline Nickyboy
  • 2007 ED30 in Grey
« Reply #9 on: October 08, 2012, 02:16:23 pm »
They have worked with the ignition off though, albeit intermittently. I push the wiper upwards and it moves easily, other times it won't shift.
