Author Topic: 012555 - Low Pressure Fuel regulation  (Read 3646 times)
Offline cheungy
  • "GO APR!"
    • SeatCupra.net
« on: May 23, 2010, 11:53:00 pm »
I drive a seat leon FR but it has the same BWA engine in the golf t with the KO3 turbo, and its on stage2+ upgrades (autotech HPFP).
I been out for a drive today on the mountain routes and going at a quick pace alot of bends etc ...after driving for about 100miles+ the car started to choke/cough but no engine light on the dash anyways i stopped for a bit and let the engine cool off (temp was okay on the dash). after about 30min break we drove off again I was a bit worried so I took it easy but it never happened again so far..after the event I went back home and did a auto scan using vagcom and came up with a fault hope you guys can help with this.
01-Engine -- Status: Malfunction 0010
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1P0 907 115 D HW: 1P0 907 115 D
Component: 2.0l R4/4V TFSI 0020
Revision: --H14--- Serial number: SEZ7Z0E3320055
Coding: 0303000318070160
Shop #: WSC 25038 576 94115
1 Fault Found
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
P310B - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 3
Mileage: 102466 km
Time Indication: 0
Date: 2000.00.00
Time: 14:56:36
Freeze Frame:
RPM: 1668 /min
Load: 11.0 %
Speed: 24.0 km/h
Temperature: 86.0°C
Temperature: 51.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.097 V
Readiness: 0000 0000
specs:- bwa engine/ko3 turbo/autotech HPFP internals/forge cai/eurojet TBE/ (no remap...yet)
been told to replace the part and also change the fuel filter that would solve the issue (it has not happened yet but it would be nice to prevent this happening again)
many thanks!
MK2 PRE-FL SEAT LEON TFSI SPORT - APR K04
  • -Receive: 453
Re: 012555 - Low Pressure Fuel regulation
« Reply #1 on: May 24, 2010, 12:00:44 am »
You should also check your cam follower should the problem not lie with the low pressure fuel sensor.
Offline cheungy
  • "GO APR!"
    • SeatCupra.net
« Reply #2 on: May 24, 2010, 12:04:09 am »
Cam follower was replaced recently along with HPFP Internals not had any issues until today however after a break (30mins, Left the car on idle then switched off) the car seems alright now but this is the error I recieved after doing the auto check with vagcom.
