Author Topic: ITG Maxogen - Filter cleaning  (Read 9897 times)
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
Re: ITG Maxogen - Filter cleaning
« Reply #15 on: June 06, 2010, 01:04:50 pm »
Just watch when re-oiling the filters as too much oil can cause damage to the MAF, i made this mistake with my previous car while cleaning and re oiling filters
MK7 GTI - ARRIVING DECEMBER
« Reply #16 on: June 06, 2010, 01:30:02 pm »
I have some spray left over from when i fitted the kit.  Remember finding it difficult to judge what was enough / too much
Offline Janner_Sy
  • -Receive: 113
« Reply #17 on: June 06, 2010, 02:01:10 pm »
What are your symptoms and log problems with the APR code Mike?
I have more or less same setup as you and could possibly do some comparison log's.
What sort of g/s do you achieve?
248g/s iirc.  Specified boost curve leaves a little to be desired, and lambda isnt the best.   here is a link to the logs http://www.mk5golfgti.co.uk/forum/index.php/topic,15408.0.html  .  he needs to do them again i think though.
« Reply #18 on: June 06, 2010, 03:24:24 pm »
What air flow are you getting mate?  Had 245 the 1st time and 235 on Friday!  :confused:  Some one with VF inlet (albeit with Hybrid KO4 pulled 303g/s yesterday.
jonboi_h
« Reply #19 on: June 06, 2010, 03:39:29 pm »
303g/s!!! :surprised:
Ive got evoms intake on my s3 and usually pull 250-253g/s max.
« Last Edit: June 06, 2010, 03:45:28 pm by jonboi_h »
Offline Cupra R
  • -Given: 18
« Reply #20 on: June 06, 2010, 04:02:50 pm »
Agreed, 303g/s is approx 394hp   :surprised:
I have seen 255g/s but I can't remember if this was stock filter  :signLOL:, it's been age's since I have done any test's and really should get out and do some.
If and when I can, are there any specific modules you would prefer to see first?
I'm not at home at the moment but when I do get in I'll have a look through my old log's to see what there like and send them to you for comparison.  At a recent RR I went to my boost and AFR was also done which did seem a little peculiar, I sent them off to APR who assured me they were fine and in fact my car was acheiving better than expected.  They also told of why my plot's looked like they did.
Offline Janner_Sy
  • -Receive: 113
« Reply #21 on: June 06, 2010, 04:13:26 pm »
id be pretty certain the filter is not the issue here.  The revo K1 pulls in  fine Hp with the same intake.
can some of you stage 2+ k04 geezers post up your requested and actual; boost plots please.
