Author Topic: dv replacement, help needed  (Read 8618 times)
Offline s4lek
  • -Given: 18
« on: June 17, 2010, 04:40:26 pm »
Hi does anyone know how to replace a dv , and if so is it a diy job for less technically minded person and also where abouts is it actually located.
or does it need to go ito a garage.
Offline gazbutS3
Re: dv replacement, help needed
« Reply #1 on: June 17, 2010, 05:04:51 pm »
on what car pal? GTI or ED30
« Reply #2 on: June 17, 2010, 05:07:10 pm »
It depends on the car. IIRC standard GTI cars, it's in a near-impossible place to reach. On Edition 30 cars, it's a bit easier to reach.
I'm sure someone will come along with a how-to guide!
Offline gazbutS3
« Reply #3 on: June 17, 2010, 05:08:56 pm »
The regular GTI isn't to bad but the car needs to be on a ramp really, ED30 is a doddle :smiley:
Offline Janner_Sy
  • -Receive: 113
« Reply #4 on: June 17, 2010, 05:39:43 pm »
i did mine when it was on axle stands when i fitted the forge spacer.  It was awkward but do-able.
when i removed the forge spacer, due to its chav sound, i did it on ramps and it took probably less than half of that.  still insanely awkward.
Mines k03 BTW
Offline s4lek
  • -Given: 18
« Reply #5 on: June 17, 2010, 05:42:10 pm »
Hi it's a gti.  I've got no chance of putting it on a ramp at home, so best to get it
booked in soon, the part itself is quite resonably priced but the people at Vw really do get away with daylight robbery when it
comes to fitting.
Offline Janner_Sy
  • -Receive: 113
« Reply #6 on: June 17, 2010, 05:55:42 pm »
dont pay anyone to do it in a dealership.  go to a small independent garage and it sholdnt cost any more than £20 to get fitted.  all they have to do is remove the cover from under the engine(2 minutes) and remove and replace the DV(only 3 bolts, just awkward to reach)
on a ramp id say 1/2 hour start to finish, and no more
Offline s4lek
  • -Given: 18
« Reply #7 on: June 17, 2010, 06:38:31 pm »
I've already booked it in at the Vw , so I'll pick the part up instead and get someone independant to do it,
I've also got a pcv (pressure valve ) that needs replacing , Ill probably have a go my self in doing that job as I've been told it fits below the panel filter and takes roughly about 20 minutes.
Thanks for all the info guys, really appreciated.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #8 on: June 17, 2010, 07:10:01 pm »
You could do it on Axle Stands (i did mine on a Jack the first time  :signLOL:)
As Sy said it's easy to do just awkward due to its location.
I can do it on Axle Stands in about 30-40mins.
Where are you located?
Offline s4lek
  • -Given: 18
« Reply #9 on: June 17, 2010, 08:11:33 pm »
I'm in Shropshire.  Once I've got the items in hand , I'll make an attempt next weekend
depending on the weather.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #10 on: June 17, 2010, 08:14:37 pm »
If you need help pm me near the time and I'll talk you through it :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #11 on: June 17, 2010, 08:31:44 pm »
once you locate it (from underneath, bhind the engine drivers side, on the turbo)  it is self explanatory.  take bolts out, put new DV on, replace bolts, and tighten evenly.
also let the car cool down for plenty of time.  it really hurts when you dont  :ashamed:
Offline s4lek
  • -Given: 18
« Reply #12 on: June 17, 2010, 09:43:54 pm »
Will definatly take you up on that if I have any probs,
cheers once again.
  • -Receive: 453
« Reply #13 on: June 17, 2010, 10:41:30 pm »
The toughest part of that pcv renewal will be taking off the engine cover.
I start at the right rear of the engine cover. You will need to pull and swear to get it off if it hasn't been off before or the grommets weren't lubed when it was put back at the last service.
Offline Gti_Mad
« Reply #14 on: June 22, 2010, 08:13:49 pm »
Hey lads think my dump valve is perished 2 as it seems more and more gutless as time goes by i have a 06 plate gti bog standard... any idea were i can get a replacement????
