Author Topic: Water pump  (Read 2853 times)
Offline Syrag64
Water pump
« on: July 02, 2010, 03:31:36 pm »
I'm having cambelt done on monday, so i thought i'd get waterpump done at same time (car done 63k) i've just ordered a water pump from stealers, should i have gone to eurocarparts? or is it better to get genuine parts?
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
Offline kbish73
Re: Water pump
« Reply #1 on: July 02, 2010, 03:41:17 pm »
i got my belt and pump done last month and used vw parts i would recommend using the vw stuff when it comes to stuff like this ! just my thoughts  :smiley: :smiley:
3dr 2006 gti steel grey 18" monzas sunroof cruise control parking sensors,giac stage1,miltek cat back,Pannel filter,tarrox discs .....
Offline ub7rm
  • -Given: 35
  • -Receive: 43
Re: Water pump
« Reply #2 on: July 02, 2010, 04:58:11 pm »
Given the hassle of fixing it if it goes wrong I think its worth spending a couple more quid on the genuine article.  They are only about £30 from the dealers.  That said, one with a metal impellor rather than the OEM plastic is probably better.
Sepang Blue S4 BE Avant
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
Re: Water pump
« Reply #3 on: July 02, 2010, 08:09:04 pm »
Why make something in metal when you can make it in plastic and it can last half as long :stupid:
Offline Gti_Mad
Re: Water pump
« Reply #4 on: July 02, 2010, 08:11:58 pm »
if anything was 2 go on iver 1 it would be the bearing not the impellors lol
  • -Receive: 453
Re: Water pump
« Reply #5 on: July 02, 2010, 08:17:34 pm »
atm I very much doubt that you'll find a pump with a metal impeller for the Mk5.   :sad1:
Offline bodger00
  • -Receive: 20
Re: Water pump
« Reply #6 on: July 02, 2010, 08:24:41 pm »
True - but i think you missed my point  :wink:
Offline Gti_Mad
Re: Water pump
« Reply #7 on: July 02, 2010, 08:53:51 pm »
ooppppppps my bad  :sad1:  :signLOL:
Offline Syrag64
Re: Water pump
« Reply #8 on: July 02, 2010, 10:10:42 pm »
Cheers guys looks like i made the right choice  :grin:
Think i've got a slightly noisy release bearing too,  :scared: is it anything to worry about?  Will be upping the power in the near future hopfully, so i expect i'll be putting a new uprated clutch anyway!  :wink:
Offline flyboy1976
Re: Water pump
« Reply #9 on: July 03, 2010, 04:59:15 pm »
Always go genuine on itwms like that as the water pump isnt the strongest part on the mk5 gti. mine was done under warranty at 20k as it was noisey!  :surprised:
